rjkoop
- September 17, 2015
- Ottawa, Ontario
- 1999 Ford Explorer
Anyone rebuild a rear wiper motor on a 1999 Ford Explorer? My son's wouldn't turn. I took it out and lubed the spindle. I'm trying to reassemble and I can't remember which way the spindle should be oriented. There is a metal plate on the spindle base which has to contact 4 small arms from the cover plate. Can anyone help out on the orientation for this?
Also does anyone know what the pins are on the 4 pin connector? I was hoping to hookup a multimeter to ensure it's getting the proper voltage on each setting. And can I assume that the motor body is used for ground?
