Rear wiper problem. | Ford Explorer - Ford Ranger Forums - Serious Explorations
Rear wiper problem.
stacypeters26
kansas city, mo.
98 explorer XLT
I have a 98 ford Explorer XLT. I replaced rear wiper motor and rear wiper control switch. But rear wiper still does not work !!:exp:
Join the Elite Explorers $20 each year.
Elite Explorer members see no advertisements, no banner ads, no double underlined links.
sean99
Sunnyvale, California
01 Limited 5.0
Did you check your fuses or relays?
BrooklynBay
Moderator & long time member.
Staff member
Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
1998Explodasport
Brockton, Ma
2001 Explorer Sport
Just like someone already said check your fuses and relays. The relays are under the hood in the power distribution box.
crunchie_frog
Johnson City, TN
Multiple 99-00 5.0 AWD
Does the motor come on at all? Is the wiper arm trying to move but getting caught on the bottom lip of the rear window/hatch and then stops? Are you able to turn it on and then go back and lift the wiper blade up above the bottom lip of the window and then it starts? These were symptoms I had and I was able to repair it. If you have these symptoms, I can share with you what I did and it now works.
gadourym
Sterling, CT
2012 XLT V6
Try double checking the door switches in the glass. Mine stopped working for a while (a couple of months) and then started working again, still haven't figured out why!
pickupman6
jack al
2000 explorer xls 4.0 ohv
yeah try the safety switch for the rear window like previosly mentioned it on the latch
marcx
satan rosa california santa rosa, ca
2001 explorer sport 2wd
Thank you guys, I was having the same problem. and it was the safety switch for the rear window. I was pulling my hair out trying to figure it out.
ericjames525
Gainesville, FL
2000 XLT
I'm having this problem currently. Where is the safety switch? Was it something you were able to fix? Or did you replace it entirely?
thanks!
jackblackjeet
Cape Girardeau, MO
2001 Explorer Sport 4WD
Hey Crunchie_frog,
I have the exact symptoms you wrote about. Do you care to share your fix?
REDREX
Cali
2000 EXPLORER XLS AWD
I recently replaced my rear motor due to it being stripped within, and now that the motor works I have another problem, my wiper does not contact the entire wipe section on the glass, it touches on the bottom and that's all, and when I bend the arm it causes another problem of getting stuck under the rear glass, and I lowered the glass closer to the latch and it still catches. Is the arm actually bent out of shape? The arm tension spring seems to lock and not let the wiper press on the glass like a design flaa...
rileybig
Ohio
2000 Mountaineer
red....I have the same problem.... Waiting for someone to reply...... Seems like the motor is cock eyed and only touching the one part of the glass when it wipes...
dimension12
Minneapolis, Minnesota
'97 sport
Spray the arm where it hinges with WD-40. It is very common for them to get sticky.
You will need to move it back and forth to work it in.
rileybig
Ohio
2000 Mountaineer
I put lubricant and worked it in. It worked! Thanks
CobraVertWV
Southern WV
'99 5.0 Ltd, '96 XLT 5.0
I had the same problem and unfortunately WD-40 didn't fix it. The blade just wasn't wiping with enough pressure. There is a TSB out for this. I replaced the arm per the TSB, and voila it works as it should. I also had another problem where the wiper motor would work intermittently - the factory dielectric grease inside the motor degrades over time - I disassembled the motor, wiped the grease off the board, reapplied new dielectric grease, and that cleared up the issue. It's nice having a rear wiper in the rain again.
rileybig
Ohio
2000 Mountaineer
How do you get to the motor? I tried to remove the back panel of the lift gate but was afraid to snap off tabs? And where did you get a replacement wiper arm? Thanks in advance
CobraVertWV
Southern WV
You have to remove the back panel. I wasn't so gentle with it and did end up snapping off two tabs IIRC. I don't have any rattling issues now though, and it is still holding together. Call Tousley Ford and order a new arm part # XL2Z-17526-AA. Be sure to ask for the "Focal Jet" discount.
rileybig
Ohio
2000 Mountaineer
If you don't mind me asking, how much was the wiper arm?
