Rear wiper stopped shooting water...common culprit ? | Ford Explorer - Ford Ranger Forums - Serious Explorations
EB4X
Orange county, Ca
95 Explorer 4X 4.0 ohv
Hey gang,
So as title states rear wiper suddenly stopped shooting water....wiper motor etc work fine, front wiper shoots water, on Explorer fuse layout link only lists relay for front wiper pump (not sure if it's there way of saying one pump for both? ) No water dripping on ground anywhere after activating it (trace of leaking tube/hose.)
Anybody deal with this and is there a common culprit / thing area to check that tends to be the issue here?
'95 4 door.
Join the Elite Explorers $20 each year.
Elite Explorer members see no advertisements, no banner ads, no double underlined links.
Mbrooks420
High Voltage.
1998 Mountaineer AWD
I’d check the water pump in the cargo area first. Check the pins for voltage when the switch is pressed.
EB4X
Orange county, Ca
/\ Thanks MB... Read about our Explorers using just one pump, but you are correct, got one in the rear for my 95 (earlier 2nd gen) .... hooked up voltmeter / setup video on phone positioned on makeshift stand and get a 10 jump to 11 volt quick burst (2 seconds) upon pressing button -- seems what should be right or close enough. Ordering replacement pump.
BrooklynBay
Moderator & long time member.
Staff member
Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
EB4X
Orange county, Ca
Did you check to see if the spray nozzle is clogged?
Watching my video of voltage recording you cannot hear any noise from the motor..... so........even if a "quieter" motor than usual I would think I would hear something....
Just for quicks I'll probably make quick adapter and blast water hose through the line tomorrow (was in the back of my mind about possible clog)
BrooklynBay
Staff member
Moderator
Brooklyn, NY
