914pete
NJ
2014 Ford Explorer XLT
Well, it couldn't have been scripted any better.
I dropped off the Ex at the dealer on Tuesday, and of course, when I pull in, the rear camera when the vehicle is put into reverse, worked just fine. Fortunately, I filmed the screen from a day earlier to prove that it was indeed happening. To confirm it, I also filmed the calendar which showed the date and time.
The service manager said they were stumped and even tried to solicit help directly from Ford engineers. Nothing (frightening, actually). He walked me to my car, started her up, backed out of my spot using the camera just fine. I said thank you and drove away. So I'm off to get a quick haircut in Caldwell, come out, put truck in reverse to pull out and whala, "rear camera not working, please contact your dealer". I could hear the gremlins under the hood giggling.
I will pull fuse 29 AND 34 for no other reason than I simply don't know what to do. Ford is not even of any help. As many of you know, this feature is incredibly useful when backing up to hook up your trailer. I'm back to the good 'ol days of getting it close and a few of us manually hooking up the hitch, unless it's an "on" day, when I can just use the rear camera. Luckily, my youngest is 13 and tall, so I should see her in my rear view mirror when backing out of the driveway.
Ercole
Hi Ercole, I know its been a few years but this post is exactly what I might write because I'm experiencing the exact same problem with my 2014 XLT. It's VERY disappointing to know that my car is 3 years newer and the problem with the Ford back up camera still exists. We're even in the same area and probably use the same dealership LOL. Did you ever find a fix for the problem?
Jhamm86
Cartersville, GA
2011 Explorer XLT
I have been reading the forum since I am having these issues with my 2011 Explorer XLT. My wife was rear ended last year and we figured that is what caused the camera to stop working. The body shop we took it to replaced the camera and fixed the wiring. The camera worked, but the lines and squares never started working again. I recently it started giving the “visit dealer” message more and more frequently. I tried the fuse pull and settings menu methods and successfully got the camera to come on. I am going to try and recalibrate the camera using forscan since I have a laptop I can use in my shop. If that doesn’t work I am going to try to get the local dealer to look at it. Thank you to everyone for all of the great info! I can totally use this at the shop I work at!
Querys
Location
Germany
Cologne
2013, Explorer Limited
I want to join this discussion.
I have a stock RVC in my 2012 Explorer and its working fine. Only the guide lines connected to the steering angle are missalinged. If the steering is straight, the guidelines show right turn.
Actually the guide lines are one full turn off target.
I tried BCM reset and all other BCM Service Procedures provided by FORScan. Nothing helped. Furthermore I tried a reset of APIM, ACM and of course the parking module. Needless to say that I had no success.
The mentioned FORScan service procedure "BdyCM – Rear Camera Calibration” is not available in my FORScan version (which is the latest available version).
Maybe someone had this issue in the past and a solution.
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
Welcome to the Forum.:wave:
When a camera is replaced, it must be programmed to the vehicle in order for all features to work. Good luck.
ExPlat
Location
AZ
2016 Explorer Platinum
My 2016 Explorer Platinum with front and rear cameras is at the Dealer right now with this problem. I get the famous 'Camera not available, see Dealer' window on the Sync screen and neither the front or rear cameras work. If I restart the car the cameras work again. I sure hope there is a error code set that they can read so something actually gets repaired.
Edit: With BOTH front and rear cameras not working when this happens it seems like the APIM would be the prime suspect, rather than having two cameras quit simultaneously, right? These cameras have the normal and wide-angle view, unlike the basic rear-only camera setup.
ExPlat
Location
AZ
Edit: With BOTH front and rear cameras not working when this happens it seems like the APIM would be the prime suspect, rather than having two cameras quit simultaneously, right? Besides, they worked on the APIM about 18 months ago. These cameras have the normal and wide-angle view, unlike the basic rear-only camera setup.
As expected the cameras worked and there were zero DTC's so the Dealer didn't do anything.
BUT: I reminded the Service Advisor about both cameras not working and it was possibly more than a simple camera going bad and that they had worked on the APIM about 18 months ago, he now has me scheduled for 9/24 for another look-see into this and other problems. At least I get a loaner each visit.
My 3/36 Bumper-to-Bumper warranty is over at the end of this month so I'd like to get any existing issues dealt with ASAP.
Querys
Location
Germany
Cologne
Just to update the comunity on my issue.
The previous owner had the vehicle in a workshop and they replaced the clockspring. Unfortunately the workshop assembled the clockspring wrong.
Today I removed the steering wheel and I turned the clockspring one revolution. Now the guide lines match the steering angle.
914pete
NJ
Is there a definitive repair to a back up camera that only works sometimes? It seems reasonable that the camera is probably fine being mine is only 4 years old and work perfectly 50% of the time.
peterk9
Staff member
Moderator
Callsign
VE3
I would think that in order to find a definitive repair, it would depend on narrowing down the actual problem part. When your rear view camera fails, is there a message that pops up to see the dealer? If the camera is intermittent, I'm guessing the only 'fix' is to replace it. When it fails, have you tried taking it out of reverse and then back in to see if the display comes on?
peterk9
Staff member
Moderator
Callsign
VE3
Querys
Location
Germany
Cologne
All cameras have to be programmed to the vehicle in which they are installed. You can have the dealer do it or you can do it using Forscan.
how do you do it with ForScan? Somewhere I saw a hint to use a service procedure called "Rear view init" but in my forscan (newest version from them) this one does not exisit.
peterk9
Staff member
Moderator
Callsign
VE3
Sorry, can't help you there. I'm not a 'Forscan' guy.
Mason Hart
Shreve ohio
2012 Ford Explorer xlt
My camera is also not working and has come on and off a couple of times. It has been off for awhile now so I was going to replace it but when I was taking the camera out to get a part number I noticed one of my license plate bulbs wasn’t working. When I touch the bulb it turns back on. Both of the bulbs were doing the same thing at one point so it makes me think it isn’t the camera but something is wrong with the wiring. Could this cause the camera to not work?
peterk9
Staff member
Moderator
Callsign
VE3
Welcome to the Forum Mason.:wave:
I don't see the connection between the camera and the bulbs. Given that you have a 2012, it is more than likely that the camera needs to be replaced. If doing that yourself, remember that the camera has to be programmed to your Explorer after installation. You can apparently do that using Forscan or have the dealer do it.
As for the bulbs, it could just be that it is a 'seating' or grounding issue. If you can remove them, check to see that the sockets are clean and the bulb connections as well.
Good luck.
Janob09
Earlysville va
2014 explorer sport
Mason,
When I was in the process of getting my rvc issue fixed I noticed the same symptom of the licence plate lights working intermittently which made me think it may have been the wiring harness that was the culprit. Ultimately I think it was a combination of a faulty camera, and lackluster splicing by the Ford "technician" but I would say most likely that if the harness is untouched and intact then the faulty camera could be messing it all up. I had the camera replaced twice, and I'm now going on 6 months without a hiccup.
Good luck.
Janob09
Earlysville va
2014 explorer sport
Peter I had a similar issue with the bulbs and I think it is just because they share a harness so depending on the wiring the camera may be messing with the voltage to the bulbs? I'm no master tech, but like I said I had a very similar issue.
Good luck.
Cambuslang
Tustin, CA
2014, Explorer
my rear/reverse video camera works intermittently! Any ideas on how to fix please?
peterk9
Staff member
Moderator
Callsign
VE3
Your thread was merged with this existing one.
Are you also getting a pop-up message saying to visit the dealer? It could be a loose wire/connection but chances are that your camera may need to be replaced. Some members have done it themselves others have had the dealer do it.
Spartapp
SPARTANBURG
2011 Explorer Limited
First post but been following for a while. I have a 2011 Explorer Limited. Original camera (BB5T-19G490-AD) starting acting up as I have read on this thread. I replaced it myself with EB5Z-19G490-A. Picture quality is great but no active assist lines as I expected (again from reading this thread). I really didn't want to reconfigure it myself so I took it to the Ford dealership. $109 and 2 trips later they can't get the active assist lines to work. They say either the camera is defective or the wrong camera. They say BB5Z-19G490-A is the correct replacement camera. Any thoughts?
K 2011 Rearview camera and blind spot sensor (BLIS) issue 2011-2016 My Ford Touch / In Vehicle Technology 2
J 2012 Rearview Camera from 2015 2011-2016 My Ford Touch / In Vehicle Technology 5
C 2013 Explorer Rearview Camera Issue 2011-2016 My Ford Touch / In Vehicle Technology 3
C Rearview camera view backwards 2011-2016 My Ford Touch / In Vehicle Technology 8
F Rearview Camera Active Guidelines 2011-2016 My Ford Touch / In Vehicle Technology 92
N 2016 Explorer Sport Front Camera Doesn't Work 2011-2016 My Ford Touch / In Vehicle Technology 1
C backup camera diagnose and replace APIM 2011-2016 My Ford Touch / In Vehicle Technology 12
B Radio/Back up Camera stops working 2011-2016 My Ford Touch / In Vehicle Technology 4
P Backup camera directional guides 2011-2016 My Ford Touch / In Vehicle Technology 2
K Touch screen intermittently not responsive and backup camera issues 2011-2016 My Ford Touch / In Vehicle Technology 4
M Sync/Phone/Camera Issues 2011-2016 My Ford Touch / In Vehicle Technology 3
C Backup Camera and boat launching 2011-2016 My Ford Touch / In Vehicle Technology 3
G Installing Backup Camera and 8" Screen in my 2013 Explorer - Is it possible? 2011-2016 My Ford Touch / In Vehicle Technology 3
M Front Camera 2011-2016 My Ford Touch / In Vehicle Technology 8
J Adding Back Up Camera - It can be done on the OEM screen 2011-2016 My Ford Touch / In Vehicle Technology 4
B Rear bumper replaced now camera grainy 2011-2016 My Ford Touch / In Vehicle Technology 5
R Rear View Camera when towing 2011-2016 My Ford Touch / In Vehicle Technology 12
V Rear view/back-up camera in 2014 is different from 2008 ? 2011-2016 My Ford Touch / In Vehicle Technology 5
C Backup camera alarm 2011-2016 My Ford Touch / In Vehicle Technology 15
D Backup Camera screen cancel button - did it disappear in 3.5.1? 2011-2016 My Ford Touch / In Vehicle Technology 5
B Rear Camera - No Guidelines Show 2011-2016 My Ford Touch / In Vehicle Technology 164
H V2.7 Backup Camera 2011-2016 My Ford Touch / In Vehicle Technology 20
Eltee Phonebook Download Problems 2011-2016 My Ford Touch / In Vehicle Technology 9
W 2011 Explorer XLT - Radio Problems 2011-2016 My Ford Touch / In Vehicle Technology 2
Daheim111 A "how to" to not have problems with MFT ? 2011-2016 My Ford Touch / In Vehicle Technology 7
B Hands free phone call problems 2011-2016 My Ford Touch / In Vehicle Technology 13
R Winter Problems with Auto HVAC Temp 2011-2016 My Ford Touch / In Vehicle Technology 4
E iOS8/iphone 6/MFT/Sync - Problems with BT calling 2011-2016 My Ford Touch / In Vehicle Technology 13
M My Ford Touch Problems- Software Update 2011-2016 My Ford Touch / In Vehicle Technology 13
P Ambient Lighting Problems 2011-2016 My Ford Touch / In Vehicle Technology 283
T 2013 explorer limited problems 2011-2016 My Ford Touch / In Vehicle Technology 6
C Update 3.5.1 first problems 2011-2016 My Ford Touch / In Vehicle Technology 15
D Problems w Nav After 3.5 Update 2011-2016 My Ford Touch / In Vehicle Technology 4
D New MFT Update - Old Problems persist 2011-2016 My Ford Touch / In Vehicle Technology 3
S SYNC Problems and the underlying story 2011-2016 My Ford Touch / In Vehicle Technology 9
F MFT Update - Now More Problems 2011-2016 My Ford Touch / In Vehicle Technology 7
L Major problems AFTER doing Master Reset! What to do now? 2011-2016 My Ford Touch / In Vehicle Technology 4
S General Sound Problems 2011-2016 My Ford Touch / In Vehicle Technology 5
B Climate Control problems after update? 2011-2016 My Ford Touch / In Vehicle Technology 6
scottfmc Upgraded: SYNC Problems remain 2011-2016 My Ford Touch / In Vehicle Technology 29
L Nav system problems 2011-2016 My Ford Touch / In Vehicle Technology 6
S Am i the only person that has no problems with mft? 2011-2016 My Ford Touch / In Vehicle Technology 42
J Official Explorer MFT Problems / Issues / Feature Suggestions Thread 2011-2016 My Ford Touch / In Vehicle Technology 205
1 Problems with SYNC. 2011-2016 My Ford Touch / In Vehicle Technology 41
1 MyFordTouch Sync problems 2011-2016 My Ford Touch / In Vehicle Technology 31
Similar threads
