okay, so heres where im at. bushin was in peices. so replaced it with hose, but me in my ability to only half do somthing, didnt mark anything, i tried the trick to realign it by manually putting it into 4x4h. which its now stuck in, but i get nothing from the motor, so my next step was to hold the sensor gear (the peice with the bushing on it) against the contacts, and i got my 4x4hi light to turn on. but thats it, nothing from the motor nothing. my shift motor is in peices under the truck right now, the magnets look good, but it does have that black ring around where the brushs make contact. and also, adding my 10cents in here, becareful when you take apart that shift motor because there is 2 cork rings on both ends of the canister(as i call it) mine just fell apart. so be careful with thoes. do you even need them though? thats my question. and if you do what do you replace them with? but end of story, stuck in 4x4hi, tricked the control module into lighting up the button, but still no shifting action, attatched to the xfer case or not. any help?
