glfredrick
- January 25, 2003
- Louisville, Kentucky
- 86-98 Ranger STX
Linkster said:I have no high or low, switch and lights work and seems to be in lower gear but no 4 wheel drive! Damn aggravating get stuck in my driveway every night after this record snow fall!
HELP!!
It almost sounds like you are a victim of bad automatic hubs...
Try putting the truck into neutral when you shift into 4 low and see if that makes a difference. Otherwise, do you hear any popping or grinding noises coming from the front axle area? If so, then your hubs are most likely not working. I recommend manual hubs (Warns).
