rebuilding trans help 5r55w
randyc
first time rebuilding trans...I put center support in and snap ring fits in their realy tight and makes it were I cant spin the drum behind the center support....is this normal,seems like im missing something.are there supost to be two bearings between the center support and direct drum?
JK080
Transmission Moderator
Staff member
Moderator
North Ga
05 F250 6.0
Just one bearing between the support and direct drum.
randyc
That's what I'm seeing in all the diagrams I think someone else put a extra one in their....their is only one plastic shell roller bearing that I see in the diagrams in the whole trans and that one is a lot smaller than the one I can't find were goes
JK080
Staff member
Moderator
North Ga
05 F250 6.0
Try to post a picture of the bearing and we will figure out where it goes.
randyc
I took a pics of it on my phone how do I get it on here
randyc
The big flat bearing on this center support is what I have but seems to tight with it and the other on the drum
R Rebuilding a 5R55S trans- What valve body kits? Transmissions & Transfer Cases 15
J rebuilding a4ld trans Transmissions & Transfer Cases 23
jorgescar69 No reverse no manual 1st after rebuilding the transmission Transmissions & Transfer Cases 22
A Rebuilding 5r55e, Ineternal Speed Sensor wire cover brittle,cracked. Replace? Transmissions & Transfer Cases 2
T Hi, rebuilding tcase info? Transmissions & Transfer Cases 2
1 "Fun" rebuilding AWD TC. Transmissions & Transfer Cases 0
W A4LD after rebuilding is stuck in forward Transmissions & Transfer Cases 1
colintrax Rebuilding 5r55e for abuse Transmissions & Transfer Cases 15
M Rebuilding M5OD - What bearings to replace? Transmissions & Transfer Cases 2
M Rebuilding M5OD - special tools Transmissions & Transfer Cases 4
G Info on rebuilding Transmission Transmissions & Transfer Cases 1
R HELP! Rebuilding A4LD- Spring Question? Transmissions & Transfer Cases 5
H Rebuilding a transmission Transmissions & Transfer Cases 3
T Rebuilding my LSD 8.8 IRS 2005 Explorer 4x4 Transmissions & Transfer Cases 9
M 4R55E transmission rebuilding problem. Transmissions & Transfer Cases 3
Z Rebuilding Valve Body, Found this Transmissions & Transfer Cases 7
Hitchhikingmike rebuilding electronic vs. old school automatic transmission Transmissions & Transfer Cases 1
gavin How To: Rebuilding a Borg Warner 4404 Transmissions & Transfer Cases 122
9 rebuilding the M5OD??? Transmissions & Transfer Cases 1
Darrman Rebuilding a 5speed? Transmissions & Transfer Cases 10
V Rebuilding your own transmission? Transmissions & Transfer Cases 8
D Is my 5R55 worth rebuilding or trashed out? Transmissions & Transfer Cases 4
R Hello everyone, question for you. I have a '03 ranger 3.0l w automatic transmission. I wanted to know the location of the test port on my trans. Transmissions & Transfer Cases 2
H 99 exploreer trans issue Transmissions & Transfer Cases 1
G 4R70W Trans shutter Transmissions & Transfer Cases 2
08EddieCA 2008 Torque Converter compatible with 2003 Automatic Trans Transmissions & Transfer Cases 2
1 1998 Ford Explorer Manual Trans: Bleeding Master & Slave Transmissions & Transfer Cases 2
T Minor trans work, now almost stalls in gear Transmissions & Transfer Cases 2
imp Auto Trans. "Glitch"? Transmissions & Transfer Cases 9
G Various little 4R70 Trans issues Transmissions & Transfer Cases 36
B 2000 Explorer trans slips in reverse Transmissions & Transfer Cases 15
P 2007 explorer trans pan with dipstick Transmissions & Transfer Cases 2
P 2006 5r55s trans swap Transmissions & Transfer Cases 1
gmanpaint P1309 code & OD stuck on, after engine/trans swap to OBDII OS Transmissions & Transfer Cases 40
M Trans code P0741 more questions, but learning Transmissions & Transfer Cases 5
C 1992 Auto Trans Downshifts Transmissions & Transfer Cases 0
K Raptor trans in an Ex Sport Transmissions & Transfer Cases 2
A P0741 8 years after trans rebuild to fix 2-3 flare. Transmissions & Transfer Cases 1
D explorer trans to ranger -interchange? Transmissions & Transfer Cases 0
S 03 explorer trans Transmissions & Transfer Cases 3
M Changing trans fluid on a 2006 XLT, not recommended? Transmissions & Transfer Cases 3
B Trans appears to freewheel downhill while in First Gear Transmissions & Transfer Cases 1
K trans cooler install Transmissions & Transfer Cases 0
T 5.0 Explorer trans problem after swap. Transmissions & Transfer Cases 12
G Trans swap into 99 Explorer from Ranger Transmissions & Transfer Cases 2
V Trans swap 99 EB to 98 EB no gears. Transmissions & Transfer Cases 14
M Trans valve Transmissions & Transfer Cases 3
08EddieCA New Front Pump 5R55S = must the trans be vertical to install the new pump Transmissions & Transfer Cases 5
S 6-speed trans OD lockout Transmissions & Transfer Cases 1
A A different approach to stuffing clutch packs in the A4LD, 4R, or 5R Trans Transmissions & Transfer Cases 7
Similar threads
