Rebuilt 4.6L lacks getup & go
JB7795
Noblesville, IN
2004 Explorer XLT 4.6L
To make a long story short, I’ve rebuilt this engine and installed a new transmission but truck lacks that throw you back in the seat kind of acceleration. Essentially the truck seems to accelerate okay from a dead stop but once you’re moving at 50-60mph and you give it gas as if you’re about to pass someone or merge onto the interstate, the RPMS shoot up to 4-5K but the truck doesn’t move along with it. You have to feather the throttle in order for it to accelerate at a “reasonable” rate. Truck seems to shift smooth as butter when you feather it, but if you try to get on it, it seems to shift pretty abruptly and harsh...So recently took my 04 Explorer to the ford dealership for a diagnostic, originally was supposed to be $80 but was told it’d cost $400 for them to diag it further so I gave them the go ahead since I’ve already invested so much of myself into this project I wanted a break but I now regret doing so because all they told me after having the truck for two days was that it needed a new battery (already knew that) and that my aftermarket plugs (Bosch) and ignition coils were to blame and I needed motorcraft instead. I thought okay I’ve had experiences with that before on other vehicles where an aftermarket part has caused problems so I buy new Motorcraft coils/plugs and a battery and guess what? Still having the same problems. And to think they wanted to charge me $1,400 to do that LOL 1/2 hour of labor to put a battery in, I’d be concerned if it took a technician half an hour to swap out a battery but I digress. I’m considering going back to this dealership this week and raising hell because I’m not quite sure what I paid $400 for, I mean I would think finding out the battery, coils and plugs were the problem would be a pretty basic $80 diagnostic but anyways just looking for some ideas thanks.
boominXplorer
Elite Ranger
Virginia Beach, Va
00 4x4 Mounty
Could be weak fuel pressure under load, maf issue or transmission related. Any codes after installing the new battery?
JB7795
Noblesville, IN
Fuel pressure is good, checked it before I took it to ford and the diagnostic confirmed the fuel system is operating properly, the only codes it has thrown are misfire codes. Before taking it to ford, the first time I drove it the CEL flashed a couple times then never came back on, put my scanner on it and it had misfire codes stored in the computer then Ford said the same thing just a few misfire codes and low voltage codes from the weak battery. But because of the misfire codes that’s why I believed it could indeed be the coils/plugs but that’s proved not to be the case. Transmission is a reman from a reputable company cost me $2,000, fluid is at the correct level as well. In regards to the engine, I had this truck completely gutted engine down to the bare block, replaced: rod & crankshaft bearings, pistons and rings, head gaskets, valve stem seals, timing set, Motorcraft crank & cam sensors, all gaskets the whole nine yards so needless to say you can already see I’ve spent a lot of money restoring this truck wouldn’t be doing it if it wasn’t in as good of condition as it is. Interior and exterior are damn near mint and I got the truck for only $500 after it sat in a garage for 5-6 years.
*edit* Wouldn’t the MAF set a code if it were causing issues?
JB7795
Noblesville, IN
Not sure about the low voltage codes but the misfire code was just P0300 for random misfire. And this is the 4.6L so it’s got a coil on plug setup, no distributor. Fuel pressure is monitored via a sensor so had to use my scan tool live data to see fuel pressure and the dealership said fuel system is operating properly. Idk if the fuel pump has ever been replaced but I did replace the filter and I can hear the pump engaging when I turn the key on. Also I’ve already replaced the catalytic converter along with everything else. Last night I got a hunch that maybe the MAF sensor was causing issues because after doing some reading apparently it doesn’t always throw a code so I went to autozone and bought a new one which is a reman sensor but I know it’s a Motorcraft sensor because of the “FoMoCo” logo on it. Don’t know if that matters though since it’s been remanufactured, anyways after installation the truck didn’t seem to like that sensor because it immediately ran worse and stalled multiple times throwing codes P0102 and P2106. Is it likely the sensor is no good or am I supposed to do some sort of reset after swapping those sensors?
JB7795
Noblesville, IN
Update, still haven’t found the source of the problem but I’m beginning to think it could be something going on with the transmission. When I try and step on it the RPMs shoot up but the truck doesn’t respond. I had the pedal all the way to the floor and the RPMs would not rise above 4K, I tried shifting through it manually as well and the truck acts the same 1st into 2nd gear seems alright but it clunks into 3rd then getting it out of 3rd is rough it won’t shift into drive unless I let my foot off the gas then it shifts but it’s very harsh. I was told by a friend who’s worked with fords for years that it could be something about the “kick down” gear in the tranny, not entirely familiar with what he’s referring to though hopefully someone can shed some light on this
JB7795
Noblesville, IN
I’ll have to give this a try and let you know, anything in particular I should expect? I just bought this transmission so I’m really hoping there isn’t anything wrong with it
M 2002 Explorer new (rebuilt engine) coding P0442 Stock 2002 - 2005 Explorers 7
Stvincnt installing Rebuilt Trans fo 04 XLS labor time ? Stock 2002 - 2005 Explorers 1
A Has anyone rebuilt his engine (4.0 sohc) without the OTC-6488 Stock 2002 - 2005 Explorers 10
L Rebuilt 5R55W with Remanufactured Torque Converter Stock 2002 - 2005 Explorers 7
M Rear-end rebuilt, but now getting intermittent strong shudder when moving out of park Stock 2002 - 2005 Explorers 7
G Just had my transmission rebuilt at 220,000 miles! Stock 2002 - 2005 Explorers 2
M 2004 ltd tranny, 120k, shop says it needs to be rebuilt Stock 2002 - 2005 Explorers 7
M Getting rear diff rebuilt, but told entire driveline should be rebuilt too Stock 2002 - 2005 Explorers 25
R Rebuilt 5r55w lost drive & reverse Stock 2002 - 2005 Explorers 2
M Rebuilt transmission slipping Stock 2002 - 2005 Explorers 4
J What to look for/Questions to ask about rebuilt tranny Stock 2002 - 2005 Explorers 7
S 2004 xlt Rebuilt Trans Down but cause is unclear Stock 2002 - 2005 Explorers 4
E Rebuilt tranny cost. Stock 2002 - 2005 Explorers 7
M HELP! Trans. Issues, recently rebuilt, shop cant figure it out. Stock 2002 - 2005 Explorers 2
T Shifter lever operation on rebuilt tranny Stock 2002 - 2005 Explorers 3
D Tranny Problem on rebuilt 2 year old. Stock 2002 - 2005 Explorers 1
J Transmission rebuilt Stock 2002 - 2005 Explorers 5
M Just had tranny rebuilt and hard shifting... Stock 2002 - 2005 Explorers 3
O Ford Factory Rebuilt Tranny Failure at 16K Miles Stock 2002 - 2005 Explorers 7
R 4.6 Rebuilt Engine Supplier Stock 2002 - 2005 Explorers 2
O Advice Needed: Transfer case — New or Rebuilt? Stock 2002 - 2005 Explorers 15
sethmorgan Rear differential rebuilt - now speedometer off Stock 2002 - 2005 Explorers 8
T Engine & transmission were rebuilt, and it has no power. Codes 305, 306, and 117. Stock 2002 - 2005 Explorers 1
L Rebuilt tranny shudders? Stock 2002 - 2005 Explorers 1
Similar threads
