Still no OD/engine braking
I have similar trouble with my A4LD. There's been no OD and no engine braking (in second manual) since we bought this '93 Explorer 4x4. First I changed everything that could be changed from the outside, then today I finally finished changing all things internal; bands, clutches, rings etc.
Still no change to 4th gear, no engine braking. So it seems the trouble is electrical or related to hydraulic pressure ? I'll get a pressure gauge and hook it up according to BrooklynBay's "most useful links", that's pretty straightforward, but if, as I suspect, that turns out to be another dead-end,
I'll be left with the electrical trouble alternative. The fault code reader shows nothing wrong with the system. As I understand the change into OD requires the coolant to be warm, the speed to be proper etc. My questions are: 1. Does anyone know the resistance values of the coolant sensor? 2. Has anyone tried to "manually" shift the tranny into OD by connecting "juice" to the OD solenoid? To completely rule out any fault in the tranny I thought I might try that. Any thoughts? Prior to trying this "manual" shift I would of course check whether the computer chooses to activate the solenoid. But if it doesn't choose to activate it, then I still won't know if the fault is in the tranny or if it is electrical, like a bad temperature sensor or the like. Or if the computer itself is faulty.
