MM07
- January 13, 2019
- MA
- 2018 Explorer Limited
Check your PM.how did you do this
My guess is that you have to change from MS-CAN to HS-CAN with the switch or vice versa.I dont see the ipc module when i connect
Can you check the link please, I'm getting and error trying to access.Check out my spreadsheet here. I try to keep it up-to-date.
FORScan 2011-2019 Explorers
FORScan 2020 Ford Explorer & Lincoln Aviator
You need that switch, like this:
Amazon product
Welcome to the Forum.Can you check the link please, I'm getting and error trying to access.
can you tell me what line you changed and what you changed it to in what module?Changed a few things on the IPC v2. I added climate to the options on the right and the outside temp. Here's a pic.
You can do it in Easy Mode without changing any of your as built data.can you tell me what line you changed and what you changed it to in what module?
Hello.Here is an updated link:
That's what I'm talking about
googlesheets said:
I'm not sure if it's my computer or not but when I open the link and then click on the Excel worksheet name it just opens another copy of the linked (CLICK HERE) spreadsheet.If anyone is looking for a direct link to the Google Docs hosted sheet above, this link should do it: CLICK ME
