Neilskidcar
- May 28, 2013
Symptom - AC is not very cold (but is cooler than the ambient air), and you can hear the compressor clutch cycling on and off when AC set to high.
Potential Solution: Simply add a can of R134a. It'll run you anywhere from $8-$40 depending on the brand, additives and hoses. I bought a can with the sealed top since I already owned a hose with gauge and piercing valve. Any of the setups you find in the store will do, as long as they have a gauge. You must have a gauge. Wear eye protection - seriously.
Process:
1) Locate the Low Pressure valve for the AC System. On my 2004 Explorer 4L V6, it is located in the front on the passenger side. It should have a black dust cap on it. Remove the cap.
2) Start the truck, turn the AC to 'MAX' and the blower to high.
3) Screw the hose into the can of R134a, and connect the other end of the hose to the Lower Pressure valve.
4) Tighten the Piercing valve on the R134a side of the hose all the way down, and then un-tighten it. Freon should start flowing into your system.
5) If your system is low on Freon, the gauge will fluctuate as the compressor turns on and off. That's normal. When the compressor is off, the gauge is measuring the pressure in the can vs. the pressure in the system and may cycle all the way up into the red before returning to the Green/Blue. Eventually the compressor will stay on and the gauge will stop fluxuating. If it remains in the red abort the project and take it to a mechanic. You have a more serious problem.
6) Let it run for 5-15 minutes until the can is empty of your system is fully charged. Periodically shake the can. You'll know you are passing freon from the can to the system when you see the freon can 'sweating'.
7) Once the can is empty, turn off the truck, unhook the hose from the Low Pressure Valve and replace the dust cover. Unhook the hose from the can and keep it for future use.
