Recommended tire pressure. | Ford Explorer Forums - Serious Explorations
the pressure on the tire is for maximum life of the tire, but most people choose comfort over that. It's really preference on air pressue. I would recommen bumping it up to about 45; then drive it and see what you think. If it is too rough, knock it down to 42; so on and so on. I run about 32 in my 35 psi tires, but I think you would be good with about 38psi because the all-terrains are a soft compound and have very flexible walls -- so the ride shouldn't be too stiff
-Drew
Thanks, I'll play around w/ the pressure. On a similiar note, I went from 255/70/R16 to the 30's, cause I had them, but they are one 15 inch rims. I can see that there is some negative camber now. Not much though. Can I adjust this by cranking the torsion bars a little? thanks
tcbradbury98 said:
.... I can see that there is some negative camber now. Not much though. Can I adjust this by cranking the torsion bars a little? thanks
No, that won't change the camber. The biggest thing a torsion twist does to the alignment is change the toe-in. You'll have to get an alignment.
BTW, changing tires and/or rims will not affect the alignment in the slightest.
