RaveDigger
- April 2, 2010
- Groton, MA
- 2000 Sport 5 speed manual
I've never seen any posts about these, so I'm curious what other members think of them:
http://www.4x4groupbuy.com/store/hicountry-offroad-dring-mount-p-9582.html
They're basically shackle mounts that bolt to the bottom of the frame. I'd like to hang them from the front of my Ex because I like the appearance of D-ring shackle mounts over solid tow hooks. This mount will accept a standard 3/4 D-ring shackle, and mounts to the frame using 1/2" hardware. If I use all grade 8 nuts and bolts, will this be strong enough to pull me when (not if) I get stuck?
Edit: I also will probably need to drill holes in the frame to mount this to, is there anything I should be aware of before doing so?
Thanks in advance!
Thanks in advance!
