greasemanicure
- November 1, 2006
- Burlington, NC
- 1996 4X4 4R->5R mod
I've posted several threads on my attempts to correct misfires on plug 4 on our 96 ex 4.0 OHV. I made the rounds through changing the plugs and wires some months ago. Changed the coil pack. Latest change was the injector for cylinder 4. Improved things but did not clear the P0304 code.
Went at it again this afternoon. Using a spark tester, checked for spark at the coil pack and at the end of plug wire #4. Good solid spark somewhere above 35kv. Checked the wire resistance at 9.5 ohms. Checked the coil pack at 11.6 ohms. Put a timing light on wire #4. No flash. Plug open??? Pulled the plug and checked from the top to the center electrode. Not open. For no reason in particular I checked resistance electrode to shell. Should be open, no? Read 6.67 ohms! This is a motorcraft AGSF42FM that I put in maybe in June and the ex has not been driven that much since then with all the misfires.
Change the plug to a new one (measured open between shell and electrode) and the misfire went away.
Anyone ever see a new plug be shorted out of the box??? First time for me.
Joe
Joe
