Red flags when buying used 2013-14 Police Explorer / Utility
crownvic
Location
MI
Nunica
2002 CVPI...2014 PIU
EDIT: sorry, this probably belongs in the PIU Sub-forum. I'd move it if I could
Hey all,
I'm moving up from a Crown Vic P71 to a Police Interceptor Utility. I'm looking for some things to watch out for. So far my list is:
1. Bubbling paint on hood
2. Water marks in spare tire well or leak marks on roof seam
3. Exterior window trim getting loose (seems easy to fix)
4. CO in cabin (Just going to use a household CO detector)
Anything else I should look for on 2013 or 2014 PIUs?
KayGee
Farmington, MI
'16 & '17 PIU
Biggest concerns are going to be how it was maintained beyond basic oil changes. Probably going to need a trans flush and fill. Probably want to change ptu lube. Probably want to check how it was decommissioned as a lot of places just seem to pull lighting and cut wires and leave stuff unfinished.
Home CO detector isn't really useful - you'll want a CO monitor (basic one ~$150).
The hood corrosion issue is what it is.
The other big issue that people are worried about is the internal water pump, but all you can really do is check for low coolant and/or coolant in oil.
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
Hey all,
Welcome to the Forum.:wave:
I've moved your thread to this sub forum since there may be issues unique to the PIU. Good luck.
ScooterMcGee
Shucktown, MS.
2013 Police Interceptor
I recently bought a 2013 off of the interwebs, just took a chance and put it in the driveway. From that experience, I can add to make sure that it has a spare tire. Mine was missing, new 18x8 rim and an Eagle RS-A $500.
I would also add that you'll want the center console metal "base". Without it the center is, well, exposed, with a wire jumble, between the cut out sections of the center mat. Mine came with the thing un-installed sitting in the back. But I quickly decided it needed to be put back.
So far so good on everything else. You'll like it.
KayGee
Farmington, MI
'16 & '17 PIU
The 75 mph rear crash rating is with the spare tire in place, but a lot of departments remove it to add a storage divider in it's place. I would assume they just put the spares into inventory and use them as needed, so they probably aren't around to be put back in the vehicle when it is eventually sold. Buyer beware - do your due diligence just like with any other used vehicle purchase. Inspect if you can. Test drive if you can. Review maintenance records/vehicle history if you can. Good luck.
my2015p71
Location
California
2015 EXPLORER PIU
Also # 3 was also recalled on mine. They stapled it together; no more glue. So that is not an issue.
peterk9
Staff member
Moderator
Callsign
VE3
#3 mentions Exterior window trim, not the interior door panel.
crownvic
Location
MI
Nunica
Thanks for all your replies. Wife now approves of a new "Blues Mobile." I'll post pics when I can.
peterk9
Staff member
Moderator
Callsign
VE3
