Refilling 5R55W tranny?? | Ford Explorer Forums - Serious Explorations
  • Explorer Forum license plate frames are available 2 for $12, or 4 for $17. For photos and more details CLICK HERE
pipewelder74
Waldorf MD
02 Explorer
I have my trans pulled out and replaced the intermediate band... swapping out TC, solenoid block and valve body since I have the opportunity. My question is- what is the correct way to fill a completely drained trans??
As forementioned it's a 5R55W..
Depends on whether the torque converter was also drained. In your case, it probably was, since the trans. was opened up.
Usually, to prevent puking out fluid initially, 4 or so quarts are added initially, engine started and allowed to idle, then add more to bring level up. This process allows the initial fluid put in to load up in the TC; this prevents the level in and above the pan from being excessive. imp
All through the ridiculously inconvienient fill tube on the bottom of the pan?
I was picturing filling it most of the way through one of the cooling line ports before I jack it back into place...
I have this, didn't catch that though..Filling through the speed sensors looks optimum. Thanks for catching ..:cool:
