RaveDigger
- April 2, 2010
- Groton, MA
- 2000 Sport 5 speed manual
I've got a 2000 Sport 4wd with the M5OD manual transmission. The sticker on my door jamb says axle code "D2" which from what I've read on the forums means that I have 4.10 axle gears with the LSD.
I see a lot of people posting stuff about regearing to 4.10 axle gears when they put on bigger (33"+) tires. If my stock Explorer already has 4.10 gears, it probably means I need to upgrade to an even higher ratio, correct?
My next question is this, what are the chances of finding both the Ford 88 rear end and the Dana 35 IFS with gears higher than 4.10? I'd like to try to avoid the cost of regearing and instead just reaxle.
Or if I can just run 33s with my current stock setup, that'd be even better, but that doesn't seem like a good idea.
