beckhm1991
- November 20, 2006
- Seattle (Capitol Hill), Washington
- '91 XLT
I have a 1991 XLT 4x4 with 3.55 gear ratios. I put a larger tire on the vehicle last year and am in need of lower gears, not enough low-end torque to get up the hills around Seattle. I have opted to purchase a new rear end with 3.73's and limited slip, I have no problem swapping out the rear axle, but have not had the opportunity to do any front end work on the X yet, other than bearings, brakes, manual hub conversion. I don't fully understand what it is I need to get to swap out the front gears, do I need to be looking for a new carrier, gear set, etc. I want to go with the most cost effective option, but need some guidance from someone who has done a gear change themselves. Any advice would be great. I have found a low mileage 3.73 rear with LSD for $300 and a front carrier for $150...anything else I might need?? Appreciate the help
