2stroke
- August 7, 2013
- Location
- 57401
- Aberdeen, South Dakota
- 1993 Ford Explorer Sport
The time has finally come for me to make a big decision for my Mazda B4000. I have been through the whole thing and much of it is new. I went through the engine and tranny as well as the suspension. The only things left are to replace the windshield and body mounts. The thing is my tires are getting so weather checked it is starting to worry me. I am going to need tires ASAP (in about a month). The thing is, I always intended to run 31" tires, and have stock 235/75/15 now. The hold up is I have 3.27 gearing. It is great for 60+ mph on stock tires, but I rarely go over 60, and also tow a lot. Option one is to keep it stock and just grab some cheap stock size tires and run it. The option I want is to regear and run 31's as well as replace the windshield and body mounts. Money is the huge factor, so I am asking for some Ideas to keep it cheap.
The rear axle I'm pretty well decided on. I want to find a LS 4.10 with disk brakes, from a 2nd gen explorer. The front is where I am stuck. My seals are leaking, so either way my front axle is coming off soon. I am not against the idea of a solid axle swap, but its totally unnecessary for my needs. Best case senario I think would be a D35 TTB from a first gen explorer with 4.10 (or is it 4.11?). To further my options, I was wondering if anyone had a link to a ring and pinion set for the dana 35 TTB for cheap. I have a little money now, but I'm hoping to keep this under $1000. I'm planning on $600 just for tires.
I am pretty well set on 4.10, as according to my calculations, this will provide a good cruising RPM, yet keep me right in the power band in 4th gear at 55-60 mpg for towing (I have the 5 speed manual). This brings me to another question, and that is recalibrating the speedometer. With 31's and 4.10 it will be fairly accurate, however, its cheap and easy to swap out the speedometer gear. I could do a little math later, but if anyone has a chart or something on which one I need, that would help.
I should mention I do have a D35 on my Mazda, its a ranger from the frame up, but an explorer from there down. I assume I have 28 spline ranger axles, but am not certain. I would prefer the 31 of the explorers, but I guess I don't see what would be wrong with the 28. This is my daily driver, that sees even harder work off the pavement on the weekends.
I have all new bushings in my front axle, as well as coil springs, wheel bearings, etc. The rear just has new drums and shoes, and I can use those for another project later. I also would like the stronger explorer leaf spring, but I don't want to lift my rear any more than it is. I am sprung over the axle, and the perches are tall. Maybe the explorer springs with a custom short perch.
Well thats enough rambling, thanks for the help in advance.
