edselman
- October 10, 2002
- Las Vegas Nevada
- 93 4 Door XLT 4X2
I am considering a remanufactured engine for my 1993 ford explorer. The old one took a massive dump in 2000, and sits at the side of the house since. Crack in the block, and the heads are probably trashed. Research I have done basically indicates that the 4.0 is in this time line:
2.9,3.0,4.0
Basically, I have a overbored 2.9. Now, I want to know if a engine place remanufactures, not rebuilds a 4.0 engine. I want quality parts used, thicker head castings (since the olds ones commonly would crack, and leak coolant into the engine, killing it, or dumping it out the exhaust pipe) and a block that I know won't be cracked. Is there a reputable company who remanufactures these engines? I don't want some junkyard engine with new parts shoved at me. I want a quality one. How can I tell if they are using the better parts, not the standard problem chocked garbage parts?
Fords wants to sell me a engine, and install it for about $6000+ dollars, far more then the value of the car. It's better left rotting then paying that outrageous price. I still might get the same problem also :fire:
Any suggestions?
Dane
edit: everything I have read indicates that alot of the problems that plagued the 2.9 got carried over to the 3.0, and 4.0. I could get new heads for a 2.9, what about a 4.0? I basically want a turn key engine, and it's fine if I would have to provide a few parts to bolt on. It's the block and heads that are molten metal on the explorer parked at the side. I want the engine 20 years down the road to be falling out at 200,000+ miles, not 64,000 like this last one!
2.9,3.0,4.0
Any suggestions?
Dane
