Removeable doors... ?? not tube or 3/4 | Ford Explorer Forums - Serious Explorations
sureshot40sw
L.A. -- Lower Arkansas
'94 SAS sport
has anybody tried replacing the hinge pin with a bolt to make easy R&R of the doors...??
I already know about tube doors, 3/4 doors and half doors.... I just wanna know about replacing the pin with a bolt.... seems like it would be easier to align the door if the hinge was in the factory position..
thanks... I figured somebody somewhere had done it... looks like a project for tomorrow... :D
well.. they are done... :cool:
as far as wiring goes... I just unplugged the two connectors on each side... pull the kick panels and pull the harness clips out so that it will pull out...
the bolt was a PITA... a 3/8" was too big for the bushing... I knocked the bushings out and drilled the outer hinge holes with a 15/64 bit and a 12 mm bolt fits perfect..... next time i'll try drilling the bushing out with a 3/8 bit...
thats about it... here are the pics..
here are the plugs
pass side... you gotta remove the puter to get to the harness...
finished product.. my nephew took this pic...:D
these are just for giggles.... now you see why his pic was sideways... :confused:
