Removing Body Mounts Permanently
X~FACTOR
Name is Ray
Valley Stream, Long Island
'97 XLT 4-dr SOHC
This might be a crazy idea but here it is anyway. :D
In pursuit of going lower would it be a good idea to remove all the body mounts and weld the chassis to body of the cab permanently, similar to a car setup. I see 1"-2" drop under there. Is this crazy or is this doable? Pros and cons?
Join the Elite Explorers for $20 per year. Gets rid of the ads! New $5 per month option.
corkey
Moderator Emeritus
Moderator Emeritus
Location
Sioux Narrows Canada
Elite Canuck,multiple ifs offender,, and musky maniac,, i wheel and i fish,,
99 xls,96 xl,91,08 Ranger
i know my 96 flexes a bunch , enuff to break loose the seal on the windsheild,, if you weld the frame to the body , when going up a curb or over a bump sideways, it might break the window,,also it might not let the frame flex as it should , and crack it somewhere,, but i could be wrong, it might take all the flex out ,,
what about just using thinner rubbers on the body mounts ??? cut them in half for thickness and get 1 or 1 1/2 inches , and keep the soft ride ,
X~FACTOR
Name is Ray
'97 XLT 4-dr SOHC
Hmm.. good point. I didn't think of the body flexing. So what is the truck missing that will make it okay for it to be one with the chasis? What makes it different than a car set up or trucks with car chasis (ie. Rav4's and such)? I'm sure there is flex there as well.
corkey
Moderator Emeritus
Moderator Emeritus
Location
they sit high ,and have suspension travel, but i have riden in a few and they have a softer ride,, might be the springs,, if the springs were softer ,not as much is transfered into the unibody, but i think they are still full frame,
Spdrcer34
Bremerton, WA
1992 Explorer XL
The RAV4, Escape and just about EVERY OTHER small 'SUV' style of vehicles are all a Unibody.
They are engineered TOTALLY different than the Full Frame vehicle that we all have. The Chassis is mounted with rubber on the top and bottom of the mounts to allow the natual flex that will happen in everyday driving. If you delete any of those bushings, you can and WILL eventually break your windshield from the flex. Even WITH the bushings in place you can still break the windshield from flexing too much....I SPEAK FROM EXPERIENCE...and can post pics/video
Ryan
corkey
Moderator Emeritus
Moderator Emeritus
Location
k, i guess they don't have a frame,, never been under them,,
