Removing Catalytic Converter Ford Explorer 2006
darrelfun
Temecula, California
2006 Ford Explorer
I am trying to remove the old catalytic Converter from ford Explorer 2006. I have the bolts, nuts, and oxygen sensors remove. It is a Y configuration. How do I remove it and put the new in.
darrelfun
2006 Ford Explorer
I need advice to remove a y shaped catalytic converter. I have it all unbolted. I trying to remove the old one. The frame seems to be in the way. I do not see how to unbolt the frame to remove it. It is stuck.
vipersinu2
The Big City of Orange City, Florida
2019 Navigator 450hp
you have to remove the crossmember and hope the bolts do not break off in the frame, there is a wright up somewhere in the forums on how to put in resistors in place of the 2 rear O2 sensors, so the check engine light stays off,
S Removing broken Stainless Steel Exhaust Manifold Studs - 4.6! Stock 2006 -2010 Explorers 7
D Help/tips removing rear axle shafts. Stock 2006 -2010 Explorers 18
2 Removing EGR will you need a new gasket? Stock 2006 -2010 Explorers 3
M Removing bad smells from A/C unit Stock 2006 -2010 Explorers 4
S Disable Ignition System to crank engine after removing spark plugs? Stock 2006 -2010 Explorers 8
N Removing the starter ('08 4.0L) Stock 2006 -2010 Explorers 5
E Removing powered 3rd row seats Stock 2006 -2010 Explorers 7
D Removing cruise control/media steering wheel switch? Stock 2006 -2010 Explorers 3
I Problem removing EGR Valve on 2010 Stock 2006 -2010 Explorers 11
P Help removing front quarter-panel Stock 2006 -2010 Explorers 2
M Removing Those Darn Trans Cooler Lines Stock 2006 -2010 Explorers 0
B Removing the Class III trailer light plug? Stock 2006 -2010 Explorers 8
B Removing the shift knob on a 2006? Stock 2006 -2010 Explorers 11
T Removing rear Ford emblem Stock 2006 -2010 Explorers 6
S removing fake wood trim Stock 2006 -2010 Explorers 2
C Removing 2010 Explorer Grille Stock 2006 -2010 Explorers 1
T Removing The Instrument Cluster Stock 2006 -2010 Explorers 5
G Removing 3rd Row Headrests Stock 2006 -2010 Explorers 2
S Removing Cross Bars From Roof Rack Stock 2006 -2010 Explorers 9
P Trouble removing door panel - need advice - thx Stock 2006 -2010 Explorers 3
R BlueMagic leather cleaner work really well on removing small wrinkles marks Stock 2006 -2010 Explorers 0
S Removing rear wiper assembly Stock 2006 -2010 Explorers 20
G removing ac vent Stock 2006 -2010 Explorers 1
D Removing 4X4 Fuse Stock 2006 -2010 Explorers 5
M Removing door panel Stock 2006 -2010 Explorers 3
J Need help removing grille on a 2007 XLT Stock 2006 -2010 Explorers 13
2 Removing scratches from tail lights Stock 2006 -2010 Explorers 0
2 Removing Roof Rack on 2006 XLT Stock 2006 -2010 Explorers 1
I removing the rear bumper! question about pins Stock 2006 -2010 Explorers 5
J Best Aftermarket Catalytic Converter Stock 2006 -2010 Explorers 3
K Catalytic Converter keeps going bad. Stock 2006 -2010 Explorers 3
W O2 Sensor and Catalytic Converter Problems Stock 2006 -2010 Explorers 3
W Possible Catalytic Converter Replacement Needed Stock 2006 -2010 Explorers 4
F Hole in the bottom of my catalytic converter? Stock 2006 -2010 Explorers 2
K Catalytic Converter for '07 LTD 4.6 Stock 2006 -2010 Explorers 11
S Trouble mating Bellhousing to Torque Converter Stock 2006 -2010 Explorers 3
R 6R60 Torque Converter Lockup/1-2 Shift Quality Issues Stock 2006 -2010 Explorers 42
E Do v8 models have torque converter lock up solenoid ? Stock 2006 -2010 Explorers 14
N Hello! Need help finding torque converter clutch solenoid Stock 2006 -2010 Explorers 1
B Torque converter? Stock 2006 -2010 Explorers 3
B Torque converter on engine swap Stock 2006 -2010 Explorers 4
J Exhaust Manifold, Hardware, & Converter Stock 2006 -2010 Explorers 9
E Weird problems. What controls torque converter lock up ? Stock 2006 -2010 Explorers 2
V 2006 6R60 transmission / torque converter issue Stock 2006 -2010 Explorers 9
E Need to replace torque converter - how many quarts of fluid ? Stock 2006 -2010 Explorers 3
J Torque converter? Stock 2006 -2010 Explorers 8
K Torque Converter Fails Twice in 1 Year? Stock 2006 -2010 Explorers 4
W Torque Converter issue? (Video link) Stock 2006 -2010 Explorers 4
W Has Anyone Replaced Their Torque Converter? Stock 2006 -2010 Explorers 30
S Vehicle surging with shudder/maybe torque converter clutch? Stock 2006 -2010 Explorers 131
Similar threads
