Removing Engine
nobodyfresh
I've been reading some of the engine removal threads and have a simple question.
Can I remove the engine with the transmission still attached to it? It will be easier to detach the transmission from the engine with it out of the vehicle... I understand that all trucks are different, but this is how I've always done it before.
I'd like to freshen up the transmission while replacing the engine, so I will ultimately be removing both. I'm hoping that I can pull them both out at the same time. I think I can as long as I disconnect the driveshafts, unbolt the crossmember, and unplug any electrical connections it will work.
Thanks in advance! I love this place!
Blake A
Florence, Alabama / Searcy, Arkansas
2001 Sport Trac 4x4
i've rebuilt my motor and when we took it out it was a pretty tight fit, im not saying it cant be done id just be careful with it.
nobodyfresh
Thanks for the reply.
Did you keep the transmission attached when you removed it? I suspect that I'll have to remove the radiator also. I have a 2ton cherry picker that can pull pretty high, and I have a nice load leveler to help with angling it.
Blake A
2001 Sport Trac 4x4
no we just unbolted the motor and pulled it out. the radiator will need to come out or else it will hit.
when we did it it looked kinda tight for both to come out but if you have a leveler it might work.
G Front timing chain replacement without removing engine Stock 1995 - 2001 Explorers 7
LoquetusofBorg Engine Bay Harness Removing Time Stock 1995 - 2001 Explorers 0
D Removing engine/exhaust manifold Stock 1995 - 2001 Explorers 0
R removing front cats, will I get check engine light? Stock 1995 - 2001 Explorers 3
B Removing EGR valve Stock 1995 - 2001 Explorers 16
D removing upper intake to access the camshaft position synchro Stock 1995 - 2001 Explorers 5
D Removing hood from 1995 XLT Tips please Stock 1995 - 2001 Explorers 4
R Removing Hatch Key Cylinder Stock 1995 - 2001 Explorers 1
J Removing Oil filter Adapter 5.0l Stock 1995 - 2001 Explorers 8
koda2000 Removing old suspension bushing trick Stock 1995 - 2001 Explorers 4
Mbrooks420 Trouble removing the rear diff fill plug Stock 1995 - 2001 Explorers 10
C Ford Explorer OHV 4.0 fuel injectors removing and cleaning Stock 1995 - 2001 Explorers 0
mounty71 Removing 2nd Gen Info Center Stock 1995 - 2001 Explorers 4
H Removing flares. Stock 1995 - 2001 Explorers 4
B Removing the entire front driveline...permentally Stock 1995 - 2001 Explorers 13
S Removing Front Drive Shaft on AWD Stock 1995 - 2001 Explorers 6
H Removing or Changing Exhaust From The Cat Back Stock 1995 - 2001 Explorers 0
L Removing rear driveshaft question Stock 1995 - 2001 Explorers 22
R Removing and replacing lower control arm Stock 1995 - 2001 Explorers 6
T Removing Rear Differential Help (Entire Axle Housing) Stock 1995 - 2001 Explorers 8
X Removing Front Drive Shaft 98 XLT A4WD Stock 1995 - 2001 Explorers 20
1 Easily removing that pesky upper right TC bolt. Stock 1995 - 2001 Explorers 1
C Removing Transmission Shift Cable from Metal Tab Stock 1995 - 2001 Explorers 3
W No pressure in fuel tank when removing gas cap Stock 1995 - 2001 Explorers 4
S Removing the gages cluster Stock 1995 - 2001 Explorers 5
M Removing evap on 4.0 sohc? Stock 1995 - 2001 Explorers 6
C Removing old oil pan gasket Stock 1995 - 2001 Explorers 3
X Removing Gas Tank "Shield" Stock 1995 - 2001 Explorers 10
E Front noise & removing driveshaft Stock 1995 - 2001 Explorers 3
E Removing AC Compress Under Pressure? Stock 1995 - 2001 Explorers 8
M Removing V8 AWD / BW4404 transfer case Stock 1995 - 2001 Explorers 7
S removing MAS to clean Stock 1995 - 2001 Explorers 4
N Removing trans/ how to test xfer case? Stock 1995 - 2001 Explorers 1
N Removing the stereo system Stock 1995 - 2001 Explorers 8
N removing coolant tubes 5.0 Stock 1995 - 2001 Explorers 5
P removing steering column? Stock 1995 - 2001 Explorers 0
D Removing speedometer drive gear from output shaft on a 1995 Explorer 4wd. Stock 1995 - 2001 Explorers 4
R Can I clean the MAF on a 5.0 without removing it? Stock 1995 - 2001 Explorers 2
G Removing driver side upper control arm bolt Stock 1995 - 2001 Explorers 40
R Removing rear axles - How do I do it? Stock 1995 - 2001 Explorers 6
J HELP- Removing Defroster Tab from Window.... Stock 1995 - 2001 Explorers 0
A Broke a line removing tank to change out fuel pump, please identify. Stock 1995 - 2001 Explorers 1
S Removing the spare tire Stock 1995 - 2001 Explorers 9
koda2000 Removing Passenger Side Air Bag Stock 1995 - 2001 Explorers 3
koda2000 removing cup holders Stock 1995 - 2001 Explorers 2
1 Removing oil filter bung to install oil filter relocation kit Stock 1995 - 2001 Explorers 4
Varsity Removing rear interior plastic piece on a Sport? Stock 1995 - 2001 Explorers 7
Jstcruz Removing windshield?? Stock 1995 - 2001 Explorers 1
C Help Removing Steering Column From Rack & Pinion Stock 1995 - 2001 Explorers 4
C removing frame rivets is easy!! Stock 1995 - 2001 Explorers 5
Similar threads
