'93BajaSport
- March 26, 2003
- Antelope Valley, SoCal
- '93 Explorer Sport
I have my '93 Sport partially taken apart to install a new clutch. I have only gotten to some peripheral parts so far; the exhaust, trans, and transfer case are still in. I am no stranger to changing engines or drivelines, but this is my first time getting this deep in an Explorer.
First, can the trans be removed without separating the t-case? If so, is it bad or dangerous or a PITA to leave it attached?
Second, I know the clutch is getting questionable, but I am also concerned about the transmission itself. For some time now it has been shifting stubbornly, especially after warming up. No grinding or noises, just slow and difficult to get into gear and shifting between gears. Could this be caused by the weak clutch, or is it more likely that the blocker rings are worn out? It's the original trans with 230,000mi.
Third, is it necessary/recommended/etc to replace the slave cylinder as well?
