Boomyal
- December 28, 2013
- Vancouver, WA
- 2006 Explorer Ltd
Has anyone done it? Something hit the bracket on my setup and bent it. I removed the 4 torx screws that hold the door flap onto the bracket, then removed the single bolt that holds the bracket onto the hitch bar. The problem is that you cannot pull the bracket out past the receptacle.
There must be a connecter at the rear of the receptacle but the connection is recessed inside the hitch bar. Also there is not enough slack on the wires to pull the receptacle far enough out of its hole in the bar to see how the harness attaches to it.
If I knew how it is anchored there would probably be enough room to do it.
