SHAD0W
- June 24, 2014
- 2018 Velar
I have a 2014 base model, and would like to have the grill painted. When I remove the front bumper fascia from the vehicle, how difficult is it to remove just the grill from the fascia, or does it come apart at all?
Ive taken many front bumper fascias off Utility PI's over the last couple years, and never paid attention to how the grill is attached, because I have had a reason to take one apart until now that I have my own.
The grille and bumper can be separated. In fact, the grille itself (once removed) can be disassembled (via unlocking the tabs) for effective painting.
There are two ways people have removed the grille. Both ways involve opening the hood, and removing the top cover off of the grille and removing the bolts connecting the top portion of the grille to the body--but one way involves leaving the front bumper on and the other way involves removing it.
After removing the top cover off of the grille and top bolts connecting the grille to the body, the grille is still connected to the bumper. You can attempt to access the bolts connecting the grille to the bumper by slightly pulling the grille forward and reaching back, etc. But some have complained of needing small hands, scraping up their forearms, forcing things and breaking tabs, etc. Hopefully you can find a thread that details this method.
The second method involves removing the bumper. Remove the cover and top bolts as mentioned before. But don't remove any of the bolts connecting the grille to the bumper. Instead, remove the screws/bolts from the bumper that run all along the bottom of the truck and along the wheel well. The bumper's plasticity allows you to pull it forward and remove the entire bumper along with the grille in one piece. Removing the bumper and grille in one go seems to work for a lot of folks--just keep in mind the large and odd size and weight of holding and removing the two connected pieces. Once both the bumper and grille are removed, you can easily separate the grille from the bumper, etc...
Hope that clears it up a bit.
