swooper
- March 29, 2008
- 1991 Eddie Bauer
My Explorer won't start. Has a new battery that is charged and I replaced the battery cables last year, so I don't think that is the problem.
I'm trying to remove the starter to get it bench tested, but I'm a little confused. There are supposed to be two bolts that hold the starter in, but at the bottom of the starter (6 o'clock position), I have a threaded rod and nut. Attached to the threaded rod is a bracket that holds the positive battery cable. When I try to remove the nut, it only loosens a couple of turns and then stops. Am I loosening the right thing to remove the starter?
