Replace front and rear brake pads? | Ford Explorer Forums - Serious Explorations
97thunderace
MD
'03 XLT
Im new to this forum and explorers and was wondering if someone could give me instructions on changing the front and rear pads or point me to where I the information is on the site. I have a 03 XLT w/4 wheel drive. Thanks in advance for the help!
Really same as most cars with disk brakes.
This is how I did mine.
1 - remove brake fluid from master cylinder (I us a turkey baster)
2 - jack up car use jack stands remove wheels.
3 - I use a C-clamp to push the piston back in.
4 - remove the caliper
5 - if changing the front rotors and you should, remove the caliper bracket and pull the rotor off might have to hit it to get it off.
6 - put new rotor on, hold it on with a lug nut.
7- put caliper bracket back on
8 - remove old pads use c-clamp to push piston rest of the way in
9 - install new pads, use the antisqueak stuff
10 - put caliper back on I grease the sliding bolts
11 - repeat with the other side and back
12 - repeat step 1 and refill with new brake fluid
13 - pump brake pedal a few times till you get a firm pedal.
14 - bleed brakes starting with the pass rear, driver rear, pass front, driver front. You will have to refill brake fluid a few times. Bleed them until new brake fluid comes out.
15 - put tires back on
16 - go for a ride make complete stops from 20, 30, 40, 50 to "set pads"
I did not change the rear rotors as I did not feel like fighting the e-brake
hope this helps
Im doing this right now...do I need to put the double notch of the pad to the top or bottom of the caliper? Saw a few diys saying both. Need immediate help!!!
Thanks!!
