EvinH
- August 9, 2013
- Catskill, NY
- 2001 Ford Explorer ST
Hey Guys,
I'm hoping someone will have some insight into what is happening on my 01 ST. I just replaced the P/S rack and pump, got everything connected, followed the instructions on how to bleed the system before starting the car and on the initial start, checked for leaks. There were none, so I went to turn the wheel to check it and it just starts turning violently on its own. The only way to stop it is to turn the car off. Is this related to the Airbag slide/sensor in the steering wheel or something else? Did I mess up the high pressure and fluid return? I have the high pressure line connected to the top port on the steering gear and the return on the bottom.
When going through my Haynes, I missed the part where it says to have the steering wheel locked when you remove the steering shaft so not to allow the steering wheel to turn freely as this may damage the airbag slide sensor. Will I need to replace this or is this an adjustment? Any advice is greatly appreciated. Thanks1
