mupmanyu
- May 23, 2003
- Denver, Colorado
- 1995 Sport
History: I have a 95 XLT Sport and I have failed emissions twice before. Turns out I had an faulty, which was then replaced by an incorrect ECM. FI finally installed the new computer today, drove around for 10 miles, and then headed straight to the emissions center. No CEL on my way to the center, and the car was running a lot better.
Problem: I failed emissions again today - seems like CEL came on during the test, as I failed on that front as well.
The main problem is that I am still running rich. My HC was almost twice the limit, and CO was 3 times the limit. This is a LOT better than the levels in my past two tests - I was almost 10 times the CO limit, and 4 times the HC limit.
Got my ECM scanned for codes at Checkers. I got the following:
i) 452 - very good sign, as my speedometer is indeed not working.
ii) 332 and 335. EGR related problems, and I am hoping I can get some leads on what to attack (DPFE, valve).
iii) 177 and 173. I expect this to be tricky as well, as I recently replaced my O2 sensor.
Any ideas? I don't have any major idling issues, my mileage was quite bad, but have not measured it with the new ECM. Obviously, I am running rich, so it is not ideal yet.
FYI, I have cleaned my spark plugs, they were fouled out since I was running rich for so long. Replaced O2 sensor, spark wires are relatively new (replaced them 2 years ago). I have cleaned out my intake, new air filter.
I don't have access to the fuel pressure, but can someone tell me if this trick will work on my 95 explorer as well (Plan B)?
http://www.explorerforum.com/Singleton/web/pages/fuelpr.html
Any help will be greatly appreciated!
