JodiJo
- March 25, 2023
- KIRKLAND WA
- 97 Explorer XLT 4wd CtrlT
97 Explorer XLT 4wd 6cyl 4l SOHC Control Trac.133960 miles. When I bought this vehicle last July I cleaned out the mass air flow sensor, IAC, a general tune up, replaced filters and belt. It didn't want to stay running, acted like it was out of gas. The idle would fluctuate, leveled out with load engaged. Replaced fuel filter changed all the fluids again. After that, it improved significantly.A month ago it started started idle fluctuation again, I replaced the IAC. N97 explorer XLT ow it's idling around 3K. I don't have any vacuum leaks or otherwise.. Do I just need to do an idle relearn? If so, what is the procedure for a 97 Explorer XLT? I've done idle relearn before but on Chevy's .Thank you in advance for your help.
