xlt1993
- November 14, 2015
- western maryland
- 1993 explorer
As some of you already know I posted about an intermittent cel and power loss with bucking and carrying on. You may also recall that all codes pointed to a faulty maf sensor. To update everyone,I replaced the maf and cleared all codes from the PCm. All was well for about 4days and about 200 miles. I was on My way to do some shopping and while going to the store the same problem returned. So when I got to the store I pulled out the code reader and pulled the codes using the koeo method. I got code 186(fault in injector pulse timing/high). I then cleared the code as required by the code reader mfg before doing the koer test. Did the koer test and received the 111 code(system pass). So now my big question Is does anyone know how to fix the injector pulse timing issue? Is that a sensor going bad or a relay or something? All issues disappeared after the maf sensor was replaced and codes were cleared. Now one problem has returned. Any and all help is greatly appreciated. Thanks In advance,Bill
