kumaxlt
- September 1, 2005
- Sacramento
- 1999 XLT
Replaced front rotors and pads with Raybestos brand. When installing the second rotor pads I noticed that the outside of the pad is flush with the outside of the rotor. As if this rotor is a smaller diameter. On the other side and on the old rotors their is about an 1/8" gap/space between outside edge of pad and rotor. I did not physically compare the two rotors as the one side was already installed. So, I went ahead and installed what appears to be a smaller diameter rotor rather then put the old parts back on. Has anyone seen this? Is this a problem? These are internet parts so I could not go to a store and trade them. Also, the part numbers on the rotor boxes are the same and correct.
