Watchman
- November 11, 2013
- Virginia
- 1993 Explorer Sport-4WD
Due to an issue to a leak at the rear side corner (outboard - to the LH tire), I replaced the driver's side valve cover gasket with Fel Pro VS50368C gasket. Both the valve cover surface and the engine surface were cleaned very well. I even made sure that the valve cover surface was flat. I put a very light coat of black Permatex RTV to both the valve cover surface and to the mating surface on the engine. I also put a bead around the holes. Then I placed the gasket on the engine side lining up the holes and then placed the valve cover on top. I also had bought new keepers and used them on under every valve cover bolt. I tightened the bolts until snug (guessing around 7-8 ft-lbs) and then retightened after a few minutes. After putting everything back together and letting it sit for an hour, I took it for a 20 mile drive. This morning I noticed that the two middle bolt areas on the outboard side (closest to the LH tire) had oil around them. None of the other bolts or surfaces had any leaking oil. Maybe I got Permatex into the holes .. I don't know. I would appreciate any help or suggestions here.
