Replaced water pump | Ford Explorer - Ford Ranger Forums - Serious Explorations
Replaced water pump
katsov
Lexington Park, MD
06 EB Explorer
Just replaced water pump on my 2006 V6. Pretty straightforward, just needed to rent a fan clutch wrench and pully wrench from autozone. Took about 3 hours, let me know if anyone has questions about how to do it.
08EddieCA
Location
CA
Los Angeles, CA
08 & 03 X (Eddie B & XLS)
What brand of water pump did you use? Just curious, did your water pump start to weep or develop play in the bearing?
07EddyB
Bowling Green, KY
2007 Ford Explorer 4.6 V8
To add to 08Eddie's question - what's your mileage? It's good to get a feeling for when they fail - they obviously don't all fail at the same mileage but it helps to get some benchmarks.
Thanks.
BrooklynBay
Moderator & long time member.
Staff member
Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
08EddieCA
Location
CA
Los Angeles, CA
Is it acceptable to replace the front cassette, tensioner, (and rear tensioner), along with the balance shaft tensioner - leavening the rear chain unchanged? I've read varying opinions on this topic.
BrooklynBay
Staff member
Moderator
Brooklyn, NY
08EddieCA
Location
CA
Los Angeles, CA
What mileage did you change your pump at?
Explorer_PL
Rockland County, NY
06EB V8
Brooklyn Bay -
you realize that changing the rear timing components is whole different ball game :)
Doing the water pump is withing reach of most of us here, doing the complete timing job on 4.0 SOHC is just a little more advanced.
BrooklynBay
Staff member
Moderator
Brooklyn, NY
I understand. I saw a thread a while back about one member replacing it while the engine was still in the vehicle. I didn't think that it would be possible since there's so little room back there but somebody managed to do it.
katsov
Lexington Park, MD
06 EB Explorer
I replaced the pump with AC delco 252-544 from amazon for $50. The truck is at 170k miles. Prior to this though, I also replaced the thermostat housing which developed a leak at the seal. I was going through a jug of coolant every 3 weeks, but couldn't identify the pump 100% until after I replaced it. There was coolant everywhere in the underside of the engine.
