Replaceing a Speedometer Cable | Ford Explorer Forums - Serious Explorations
couger77
KS
1994 Eddie Bauer
My truck has bouncy speedo cable syndrome.
I have decided to replace said cable.
How hard is it and how is this operation performed.
Thanks.
Seacrest, Out
if you are just replacing the inner cable then you can either remove the cluster or get under the truck an remove it fron the transfercase .all you need to do is expose 1 side an use vicegrips an pull the cable out an a lil bit of white gease to lub the new cable an push it back in.
