Elbereth42
- July 20, 2011
- Rochester, NY
- '03 Limited
Hey there, folks!
I've been lurking around for a bit now, and really haven't had a need to post anything, since every question I've had has been answered somewhere else. I can say for sure that I've saved many hours and hundreds of dollars thanks to you folks. Thanks!
So, now that I've put you all up on a pedestal, I've got a real melon scratcher here: Where the hell do I get a replacement power steering reservoir? I've googled both numbers on the reservoir (M536A and PA66-GF33), and can't even find pictures of it, I can't find it at O'Reilly's or on rockauto.com. I've never had rockauto let me down.
One of the nipples on the bottom (the wider one, I believe it's the outlet) is cracked along its height, almost halfway, starting from the tip. I figure it's only a matter of time before it completes the crack, and I'll have a leak, so it's not an emergency now, but might be soon.
Thanks so much for everything you folks have done, and here's hoping there's an answer to this question in somebody's head.
