Skip Towne
- October 30, 2018
- Location
- Sonora desert Arizona
- 2000 Explorer Sport
Can you replace the factory ball joints without replacing the whole control arm?
This may not be applicable in your case, but in the past on a variety of vehicles, I've had good luck with just replacing ball joint boots instead of the entire joint assuming you catch it early (see a cracked/decaying boot, or a freshly ripped one). The joints themselves don't seem to wear out, but the contamination from boot failure ruins them.
Boot replacement is easy and doesn't require removing the joint, typically factory replacement boots are just a few dollars.
one piece upper on drivers two piece upper on pass, DO NOT BUY THE ONE PIECE UPPER FOR THE PASS SIDE.... people always buy the one piece for the passenger side and then freak out when they need alignment shims and $350 at the alignment shop, just stick with the two piece upper for pass side and be done with it!!
^ Good point, but where do you find dust boots that seal properly? Polyurethane replacements such as Prothane, Energy Suspension, and Daystar are more or less covers that fit over the ball joint flange, but don't completely seal out contaminants, especially when submerged in water.
Aftermarket Universal Dust Boots | Polyurethane Replacement Dust Cover
