Brookes65
- April 9, 2009
- Sunnyvale, California
- 93 Explorer 4.0L 4X4
So horrible whining sound screamed from engine, idle ran up dropped down a little .. very sticky while doing so... The engine was about to die when I turned off the engine...
Further inspection showed the idler pulley mounting bracket had some damage to it which and the idler pulley itself had some back and forth play that confirmed that I should go ahead of replace it...
I spun the pulley's and the all spun fine... noticed the P/S pulley also had a little play in it... OH.. and replaced the water pump not too long ago and it was late my husband and were both tired and realized only after we calked the gasket sealant onto the new gasket and were getting ready to mate the parts... well that the old gasket was totally not all gone... some area's were .. some weren't.. so now I saw around the edges of the water pump look a little wet (suspiciously in the portions where the gasket was half on and corroaded ).. so I'm replacing the water pump gasket properly this time...
Anyhow.. when inspecting all this stuff I noticed that a a bit of coolant/water had created a small pool right on the upper intake i'm assuming this happened at the last few moments the truck had been on the day before.
What else would have caused the coolant to be there?
Are you suppose to able to turn the crankshaft pulley by hand?? I can't ..noticed this when I changed my water pump but after puting everything back together it ran great for a bit which made me think it was normal...
