Replacing Interior Door Pull Handle | Ford Explorer Forums - Serious Explorations
Bob_G
Burke, VA
92 XLT
I am trying to replace the interior pull handle on the driver's side of my 92 Explorer. Does it come out without taking off the entire door panel? It seems like it should, but I didn't want to start prying on it and break something else. Any tips for removing and replacing it would be appreciated. Thanks!
the handel is held on from factory by being melted on, the ebay replacement uses plastic posts, and seems much sturdier then the original, I did it on my drivers door only to have the passanger side go amonth later. You need to clear out the old holes where it was melted(when you open up the door it will be clear what needs to be done, Good Luck , Jon
Thanks to both for the help!
Jon - Thanks for the tip on the posts being melted in...I couldn't figure out why I was having to bust them out.
No problem, hope it went smoothly.
