Replacing OEM headlights with HID lights?
spr
2013 Expl XLT 4WD
spr
2013 Expl XLT 4WD
4300k is the best for light output in my opinion as a good bulb can product 3100-3400 Lumens. Anything above 4300k is more for looks.
Exactly. Lumens rule.
...and I think the sapphire blue of some of these bulbs looks a little silly frankly, but thats just me.
In the Pink
7.3 F250
Also, contrary to what some may think, as the 'K' number goes up, the actual light output (lumens) decreases.
Is that so, Peter? I thought the same wattage HID bulbs were brighter over tungsten. If that's not the case, then what do we want these things for? :D You may be right about actual output, I don't know, never tested them, but their beam pattern is more efficient and that might be where the confusion comes in. Thanks, learn something new everyday.:biggthump
peterk9
Staff member
Moderator
Ottawa, Ontario area
2020 Aviator Reserve
Callsign
VE3
If you check out the chart that spr posted in this thread, you will see that as the 'k' number goes up, the light output, measured in lumens, actually goes down.
http://www.manyadeal.com/page.html?id=24
rkeyser
2013 Ford Explorer Limite
I have a 2013 Explorer Limited with OEM Halogen bulbs. Will the 2x-OSRAM-xenarc-66340-D3S-35W-Xenon-headlight-HID-BULBS-LIGHTS-NEW-GENUINE-OEM-320892017266 work as replacements in the existing lamps? In other words, can I plug these HID bulbs into my existing plugs? The ballasts seem to be integrated with the bulbs.
Thanks,
Randy
peterk9
Staff member
Moderator
Callsign
VE3
Thanks,
Randy
Welcome to the Forum rkeyser. :wavey:
Randy, as I mentioned in my PM to you, I have moved this thread to the 'Modified' forum. There are several posts here about installing HID lights/bulbs. Good luck.
roamingphantom
NYC
2013 EX Limited, 302A
Thanks,
Randy
I thought the limiteds came with HID? Mine did - If you have HID - Yes they will. Its not easy getting to the bulbs though. I've changed mine from 4300 (factory) to 5000 (nice look) and then I went to Philip 6000 Ultinons (very nice look).
Like I said before - its a pain getting to the bulbs so I had a shop do mine. Also remember most of those Ebay bulbs aren't really genuine bulbs so you get what you pay for. I'd recommend hidconcept.com that's where I got my 5000 from and they have been well so far until I swapped to 6000 - got the 6000 from kbcarstuff.
good luck and post pics after your mod
peterk9
Staff member
Moderator
Callsign
VE3
Only Limiteds built for the Canadian market come standard with HID. For Limiteds built for the U.S. market, HID headlights are an option.
s1000rr
Jersey
2013 explorer sport
I have the 35watt 6000k hid kit in my car. Night and day difference between the stock and these. Thats usually my first mod on anything that doesnt have hid's. Very simple installation too.
I buy my kits at ddmtuning.com. Always had great service with them, plus the bulbs have unlimited warranty.
LukerDooker
N.E.
2013Limited 301A TuxBlack
"I have a 2013 Explorer Limited with OEM Halogen bulbs. Will the 2x-OSRAM-xenarc-66340-D3S-35W-Xenon-headlight-HID-BULBS-LIGHTS-NEW-GENUINE-OEM-320892017266 work as replacements in the existing lamps? In other words, can I plug these HID bulbs into my existing plugs?
The ballasts seem to be integrated with the bulbs. "
+1
i doubt these will fit in a Ltd with Halogen but ...anyone?
ihatia
Ontario
2014 Explorer Sport
Does anyone in the US know if Ford has a OEM HID kit for the Sport?
I went to the dealer today and they told me that if they change the DRL's to the parking lights it will cause an issue with a controller.
Service Manager says to wait until the new year and see if Ford has a OEM HID kit. He also said that they already have them in the US.
I have searched but have not found anything.
I have a 2014 Sport that I will be picking up next Wednesday and wanted to confirm this before I pick it up.
And any owners that have used after market HID kits have you had any issues?
LakersCentral
Southern California
2014 Explorer Sport
avg2424
2014 Sport
I'm surprised about that 'yellow tint' part. When my OEM HID's reflect off signs, I notice a slight hint of blue.
You see blue because of the projector bulb. Think of a prisim. You will see the blue due to light refraction due to the curvature of the projector glass.
peterk9
Staff member
Moderator
Callsign
VE3
Did you mean the headlight lense? I don't have projector bulbs.
avg2424
2014 Sport
Nope, meant projector. Didn't read that you had a 2011. There shouldn't be very much refraction on your headlights.
Igottaguy
13 XSport 402 & Tow
13 Exsport HID's returned to stock
I have been running high quality HID's in all my vehicles including sleds, four wheelers and bikes. I was running a 55w kit for my headlights and a 55w kits for the driving lights. I had zero problems in my 09 & 11 edge sports and none in the exsport until now. The kits were professionally installed with delays, resistors and capacitors. After hours of testing and messing around, I had my dealer check all the systems and was charged over $300 to have them put the stock bulbs back in the care. I have had the HIDs bench tested and they perform as they should.
What kits have been guys using with good success? Has anyone frankenstiened the factory HIDs from a limited into a sport?
peterk9
Staff member
Moderator
Callsign
VE3
Welcome to the Forum Igottaguy.:wavey:
As per my PM, I have merged your thread with this one on HID;
http://www.explorerforum.com/forums/showthread.php?t=385161
You may also want to check out;
http://www.explorerforum.com/forums/showthread.php?t=379829
http://www.explorerforum.com/forums/showthread.php?t=397594
Good luck
s1000rr
Jersey
2013 explorer sport
There are a few threads on HIDs already, take a scroll through there. Lots of information.
Many ppl here have different sources on where they get the hids, coolbulbs i think is one of the known ones.
Personally I get mine from ddmtuning.com. Never had any issues with mine, so far have one set in my bike thats still working over 5 yrs. Plus, bulbs have unlimited warranty which is pretty sweet.
Have them in my 13 exsport as well with no resistors or capacitors, so im not sure what problems you are running into.
good luck
Alan in AZ
Phoenix AZ
2013 Limited 4WD
Peter this is quite untrue.
Color temperature and light output in lumens are essentially unrelated in an abstract sense.
e.g. If I buy an 8000K and a 6000K bulb I won't know which is brightest in lumens - it could be either one.
Similarly I can buy an old style high power floodlamp of several thousdand watts @ approx 3500K and it will be very very very bright (in lumens)...
If I have a single incandescent lamp its brightest point (in lumens) before it finally burns out (as I increase the supply voltage) will be its highest color temperature. It will likely be the apparently brightest point too.
Now above a certain point (~7000K) "useful" (to humans) apparent light intensity does diminish as color temperature goes up - personally I find Purple light to be highly objectionable - and I would expect rather useless for driving. Besides for me at least, accurate color rendering is highly beneficial to recognition at night (so I don't like sodium street lights either).
At lower color temperatures (say 3000K-6500K) the apparent brightness to humans actually increases with increasing color temperatures.
Think of it like this - as humans we are optically attuned (and optimized) to the natural daylight we have all day long (~6500K) - makes sense that we perceive less brightness as we diverge - either way - from that color temp.
Alan
1 Replacing 2nd and 3rd row dome/map lights in an Explorer? Modified 2011- 2019 Explorers - Tuning & Mods 4
R Replacing 2011 rear bumper for towing Modified 2011- 2019 Explorers - Tuning & Mods 0
S Replacing back up or reverse light Modified 2011- 2019 Explorers - Tuning & Mods 1
A Replacing Front Emblem Modified 2011- 2019 Explorers - Tuning & Mods 18
T Replacing bench with 2nd row bucket seats Modified 2011- 2019 Explorers - Tuning & Mods 124
M OEM Horn Swap Modified 2011- 2019 Explorers - Tuning & Mods 1
B Source for pins for various OEM connectors Modified 2011- 2019 Explorers - Tuning & Mods 0
B Used OEM backup camera installed, shows very grainy/squiggly, video link provided. Modified 2011- 2019 Explorers - Tuning & Mods 6
BAD430BENZ Anyone want to sell their OEM springs ? Modified 2011- 2019 Explorers - Tuning & Mods 0
B Upsizing tires w/o changing OEM 18" rims - what size and is it safe? Modified 2011- 2019 Explorers - Tuning & Mods 4
T Oem reverse sensing system Modified 2011- 2019 Explorers - Tuning & Mods 0
E Factory OEM oil cooler Modified 2011- 2019 Explorers - Tuning & Mods 0
X 17" OEM Wheels Questions Modified 2011- 2019 Explorers - Tuning & Mods 12
B 275/45R20 Nitto NT421Qs on Sport OEM 20x9s Modified 2011- 2019 Explorers - Tuning & Mods 12
T Removing OEM Hid Headlight Bulbs Modified 2011- 2019 Explorers - Tuning & Mods 7
Y Installing OEM Subwoofer 2011 XLT Modified 2011- 2019 Explorers - Tuning & Mods 2
P Adding OEM Class 3 Trailer Hitch? Modified 2011- 2019 Explorers - Tuning & Mods 3
BAD430BENZ interceptor grille....new oem grille ? Modified 2011- 2019 Explorers - Tuning & Mods 57
BAD430BENZ OEM hood for custom project ! Modified 2011- 2019 Explorers - Tuning & Mods 9
V OEM parts that are interchangeable from one trim to another? Modified 2011- 2019 Explorers - Tuning & Mods 6
H Larger Tires on OEM & Aftermarket Wheels Modified 2011- 2019 Explorers - Tuning & Mods 124
L QUESTION - Would a 17" OEM Steel Wheel fit on the Sport model? Modified 2011- 2019 Explorers - Tuning & Mods 28
D Best place for 20 inch OEM wheel Modified 2011- 2019 Explorers - Tuning & Mods 3
I Changing OEM Halogen bulbs with something else! Modified 2011- 2019 Explorers - Tuning & Mods 1
R OEM 20 inch 5 spoke centercaps Modified 2011- 2019 Explorers - Tuning & Mods 4
J Trailer Hitch Conversion to OEM? Modified 2011- 2019 Explorers - Tuning & Mods 6
A full led headlights and front grille Ford Explorer 17 Modified 2011- 2019 Explorers - Tuning & Mods 20
D Aftermarket headlights Modified 2011- 2019 Explorers - Tuning & Mods 8
A new led lights front bumper and headlights Modified 2011- 2019 Explorers - Tuning & Mods 3
mmartin028 2016 LED headlights in a 2015? Modified 2011- 2019 Explorers - Tuning & Mods 18
J Questions pertaining headlights Modified 2011- 2019 Explorers - Tuning & Mods 17
R RetroFitted Headlights - need your opinion Modified 2011- 2019 Explorers - Tuning & Mods 24
R 2012 headlights hid to halogen Modified 2011- 2019 Explorers - Tuning & Mods 5
P Aftermarket Headlights-where to get? Modified 2011- 2019 Explorers - Tuning & Mods 6
B Upgrade 2014 Explorer headlights Modified 2011- 2019 Explorers - Tuning & Mods 9
R Headlights quit working Modified 2011- 2019 Explorers - Tuning & Mods 21
W Custom Headlights and Fog by RIHIDS Modified 2011- 2019 Explorers - Tuning & Mods 25
A Adding "Automatic headlights"? Modified 2011- 2019 Explorers - Tuning & Mods 1
C How to adjust headlights Modified 2011- 2019 Explorers - Tuning & Mods 2
T How do i aim the headlights horizontaly Modified 2011- 2019 Explorers - Tuning & Mods 9
F Smoke tail/headlights Modified 2011- 2019 Explorers - Tuning & Mods 34
H New Mods! Ventureshield Clear Bra, Lamin-x Tinted Headlights & Tint all around (Pics) Modified 2011- 2019 Explorers - Tuning & Mods 23
B Does anybody know is smoke tinting the headlights is NOT LEGAL in Canada?? Modified 2011- 2019 Explorers - Tuning & Mods 2
W 13 Explorer Sport - changed stock headlights to 8k HID Modified 2011- 2019 Explorers - Tuning & Mods 29
M HIR Headlights from http://www.hirheadlights.com/ Modified 2011- 2019 Explorers - Tuning & Mods 2
R Customized Headlights Modified 2011- 2019 Explorers - Tuning & Mods 6
J Headlights Modified 2011- 2019 Explorers - Tuning & Mods 8
E Does it help to swap the standard halogen headlights for aftermarket brands? Modified 2011- 2019 Explorers - Tuning & Mods 11
W Sema explorer headlights Modified 2011- 2019 Explorers - Tuning & Mods 1
Similar threads
