replacing rear door speaker grills
turbo2ltr
AZ
2016 Police Interceptor
At some point I realized my FPIU has rear speakers, but the OEM door panels don't have any speaker grills. Anyone ever replaced the grills? Can you replace just the grill part or did you have to replace the whole door panel?
Hallandry
Aurora, co
2017, Explorer, PIU
turbo2ltr
AZ
Hallandry
Aurora, co
2017, Explorer, PIU
oops..sorry. Yes those panels pop out and the speaker grill should be behind them.
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
Satyroginger
CALIFORNIA
2013 Explorer interceptor
I'm pretty sure they are plastic welded together. I just bought a set of rear door panels off eBay from a 15 explorer. At a fairly good deal of $205 for both. The PUI doors panels have small markings on it that i think is for drilling your own holes.
peterk9
Staff member
Moderator
Callsign
VE3
.......... The PUI doors panels have small markings on it that i think is for drilling your own holes.
I believe a member here did exactly that.
VCFP153
Ormond Beach FL
2021 PIU
Mine has speaker grills back there already. I guess that's another part of the Interior Upgrade Package. As an aside, it turns out it does NOT have the big accessory feed harness that would normally be under the console mounting plate. I guess they figure if you want the full retail console, you're not going to be using the harness...
ronaconda
Salt Lake City, Utah
2014 PIU
I wondered this as well on my 14 PIU...speakers are there but no grilles. I actually need a speaker too as the passenger side is not there.
Spork
2014 Explorer PIU
I used a Dremel to open up the holes to match the circle pattern molded into the back of the panel. Attached some speaker grill cloth ( available at fabric stores or audio retailers) to the back of the panel to cover the holes. Looks almost stock-
peterk9
Staff member
Moderator
Callsign
VE3
Pictures??
Spork
2014 Explorer PIU
I will try to get some pics tomorrow- unfortunately the panels are installed in the car , I didn't take any in-process pics.
Spork
2014 Explorer PIU
Took some pics today but can't figure out how to upload them to the forum- tried search feature with no luck. Any ideas?
RhinoQuartz
17 Explorer Base
You can buy an elite explorer membership ($20/yr) which will allow you to upload pics straight to the forum server or you can upload to an external image hosting website (eg imgur) and post the link here.
peterk9
Staff member
Moderator
Callsign
VE3
There might be another way by using the "Image" icon in a post next to the 'Smiley'. I've never tried it since I've always had the Elite Explorer membership but I've seen several pictures posted by non Elite members that don't have a link in their post.
RhinoQuartz
17 Explorer Base
Wait so I didn't have to spend 20 bucks to upload those 2 pics 3 months ago??
Oh well, at least I have no ads!
peterk9
Staff member
Moderator
Callsign
VE3
Only those pictures posted using "Upload a File" are saved to the Forum's servers. Others could disappear without notice as happened with those that used Photobucket before they changed their policy.
RhinoQuartz
17 Explorer Base
I'm definitely derailing this thread, but I remember it not working for some reason so I just bought an Elite sub. Much easier. Its a real bummer to look through old posts and there's no pics because most of them were on photobucket.
KayGee
Farmington, MI
'16 & '17 PIU
It works the same way it has for years and the same way most other sites on the internet work. Images have to be hosted somewhere, either on the site or at another site, then you use [*img] insert URL of your image between these html tags [/img*] to display the image within your post. Remove *'s from img tags.
If you use imgur to host your images, there are a bunch of different links to choose from to post your images. You can also use Flickr or any other image hosting site.
