replacing rear wheel bearing need help!! | Ford Explorer - Ford Ranger Forums - Serious Explorations
2002xlt4.0
Clinton Maine
2002 xlt
I am replacing my rear wheel bearings on my 2002 explorer and i was told i needed the bearing, snap ring, flang, and a inner and outer seal
my question is do i need the seals?
the dealership said there was an inner and outer seal i would under stand if it had a soild axle but on irs i dont see where it is needed
The must be thinking of the rear differential. They came with two piece seals that are know to leak(mind does) and you replace them with a one piece seal. But you would be pulling the rear shafts out, but you don't need to when replacing your rear WB's.
yeah thats what i thought they where talking about but i wanted to make sure
