Replacing Seat Filters $$$$
Bill #5 Explorer
Chicago Area
2016 Explorer XLT
Had the Limited in yesterday to finally get caught-up on all the TSB stuff. I'm almost out of warranty at 34,800 miles.
Had the tires rotated. Not due for an oil change for another 1,000 miles or so (changing every 7,000 miles with Mobil 1 0W30).
I asked to have the seat filters changed, since the service interval is 30,000 miles. Service advisor called me and said they looked fine and did not need changing. I said "change 'em anyway". He said the charge is about $260. :eek:
I then said "whoa nilly". :D
I'll wait till the 60,000 mile mark and see how they look then.
Good job by the service advisor.
Joe Dirt
07 Camry
Those filters are about $30 online... Motorcraft FS-104
jrmexplorer
2011 Limited
Wow.... $200 in labor? I cant imagine they are that hard to do?
Joe Dirt
07 Camry
Like the cabin air filters in my Camry- $70 at the dealer. Or: Buy $6 filter, open glove box, push 2 tabs to release filter cover, remove filter, put in new filter, snap cover back on, close glove box.
Not sure how the filter on the Ex is situated, but I'd mess with it for a long time to save $200... That seems ridiculous...
cnsheets
2011 Explemoner
Which trim has the seat filters? Is it just for the heated AND cooled seats? Just heated seats? I know I have a cabin filter, but never heard of a seat filter. I do have heated seats, but not cooled.
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
If you eat a lot of beans, do the seat filters require changing more often? :D
Bill #5 Explorer
Chicago Area
2016 Explorer XLT
Just the cooled seats require the filters.
bluelion
Spring, TX
2012 EX Limited
Interesting. Didn't know about seat filters. That almost sounds like something a service tech would make up to sucker a woman into paying more money
Bill #5 Explorer
Chicago Area
2016 Explorer XLT
That's sexist.:D
Bill #5 Explorer
Chicago Area
2016 Explorer XLT
Beans, beans, they're good for the heart, the more you eat them, the more you...........!
toms2012
Kentucky
2012 Explorer
Myi base Ex only needs blinker fluid. :D
MikeFreas
VA Beach VA
Do the seats have to be pulled to change them?
I just looked at the owners manual and it's a easy change. No reason to charge 200 bucks, maybe 20.
corkey
Moderator Emeritus
Moderator Emeritus
Location
Sioux Narrows Canada
Elite Canuck,multiple ifs offender,, and musky maniac,, i wheel and i fish,,
99 xls,96 xl,91,08 Ranger
i almost thought this thread was created to be funny,
Bill #5 Explorer
Chicago Area
2016 Explorer XLT
Not sure. But it is not an easy swap like a cabin or engine air filter. I think the Service Advisor said something about the seats needed to be "taken apart" in some way.
VinceL
Frisco, TX
2013 Explorer Limited
The replacement procedure is on pgs 162-163 on the electronic version (which can be found here) of the 2012 users manual. Doesn't look to difficult, especially for $260!
Bill #5 Explorer
Chicago Area
2016 Explorer XLT
Hummmm. Interesting. That does look pretty easy. Thanks for the link. I'll ask another dealership what they charge. It's my company car, but I still don't like over-spending company funds.
Bottom lime, my truck is barely one year old. The filters are clean because of that. I just drive a ton. The AC seats were only use one season.
VinceL
Frisco, TX
YW.
It is also my impression that the fans run when warming the seats too, since it uses the same component to warm the seats as it does to cool them, just in reverse. This could lead to the filters getting clogged faster.
S Replacing heated/cooled seat fan? Stock 2011 - 2019 Ford Explorer Discussion 7
M Replacing Interior Trim Stock 2011 - 2019 Ford Explorer Discussion 1
T Options for replacing LED low beams 2016+ Stock 2011 - 2019 Ford Explorer Discussion 4
D Can I substitute "tags" when replacing transmission? Stock 2011 - 2019 Ford Explorer Discussion 0
S Pulled CV joint apart - Replacing ATF after removing axle? Stock 2011 - 2019 Ford Explorer Discussion 18
A Replacing LF drive shaft Stock 2011 - 2019 Ford Explorer Discussion 1
R Replacing lower black plastic components on Sport Rear Bumper? Stock 2011 - 2019 Ford Explorer Discussion 2
M Need advice in replacing alternator on 2014 Explorer Stock 2011 - 2019 Ford Explorer Discussion 2
G Replacing front grille Stock 2011 - 2019 Ford Explorer Discussion 3
T How to: 2017 Explorer - Replacing front camera Stock 2011 - 2019 Ford Explorer Discussion 23
P Replacing Condenser Stock 2011 - 2019 Ford Explorer Discussion 15
K 2013 Explorer Grill replacing. Stock 2011 - 2019 Ford Explorer Discussion 11
O Replacing 2013 Explorer Fog Light Lens Stock 2011 - 2019 Ford Explorer Discussion 1
M abs light on after replacing rear rotors and pads all wheels Stock 2011 - 2019 Ford Explorer Discussion 1
B Help.... Replacing headlamp bulb cover Stock 2011 - 2019 Ford Explorer Discussion 0
B 2011 Ford Explorer Replacing Fan Assembly Stock 2011 - 2019 Ford Explorer Discussion 7
D Replacing the Windshield Wiper Switch Stock 2011 - 2019 Ford Explorer Discussion 7
S Replacing front passenger window Stock 2011 - 2019 Ford Explorer Discussion 5
S Replacing air filter Stock 2011 - 2019 Ford Explorer Discussion 7
M Replacing a broken fog light Stock 2011 - 2019 Ford Explorer Discussion 13
S 2018 Explorer Platinum Driver's Seat Heater Module Fail (and Solution) Stock 2011 - 2019 Ford Explorer Discussion 2
K Second Row Seat - Headrest Stock 2011 - 2019 Ford Explorer Discussion 2
R 2011 power seat problem Stock 2011 - 2019 Ford Explorer Discussion 6
M Looking for help with front seat removal Stock 2011 - 2019 Ford Explorer Discussion 3
D Power third row seat switch wiring harness? Stock 2011 - 2019 Ford Explorer Discussion 0
Z 2013 2nd Row Seat Stuck in Tumbled Position Stock 2011 - 2019 Ford Explorer Discussion 7
B 2015 Sport Rear 40/60 Seat Removal Stock 2011 - 2019 Ford Explorer Discussion 2
ISTGradFromPSU 2017 Explorer Driver Side Massage Seat Issue Stock 2011 - 2019 Ford Explorer Discussion 4
D 2016 Ford Explorer Sport seat uncomfortable Stock 2011 - 2019 Ford Explorer Discussion 1
B 2016 Explorer Sport Driver seat heater working for back but not seat? Stock 2011 - 2019 Ford Explorer Discussion 3
N drivers heated seat not working, cooling ok Stock 2011 - 2019 Ford Explorer Discussion 11
R How to: Guide to fixing rattling noise in upper 60 rear bench seat Stock 2011 - 2019 Ford Explorer Discussion 0
R Advice needed to remove upper seat cover of 60 seat? Stock 2011 - 2019 Ford Explorer Discussion 0
B Third row seat removal Stock 2011 - 2019 Ford Explorer Discussion 0
T 2014 Sport Seat comfort Fix Stock 2011 - 2019 Ford Explorer Discussion 5
R Why are the heated seat cushions so different in price... Stock 2011 - 2019 Ford Explorer Discussion 0
R Popping sound from 2nd row seat behind driver side Stock 2011 - 2019 Ford Explorer Discussion 8
H 3rd Row Seating: only one seat is working Stock 2011 - 2019 Ford Explorer Discussion 5
R Help finding correct part number....... (Heated seat) Stock 2011 - 2019 Ford Explorer Discussion 5
S Key on power for aftermarket seat heaters in base 2017 explorer Stock 2011 - 2019 Ford Explorer Discussion 1
W Passenger Heated Seat Strange Issue Stock 2011 - 2019 Ford Explorer Discussion 2
A Front seat movement when using keypad to unlock Stock 2011 - 2019 Ford Explorer Discussion 4
N drivers heated seat not working Stock 2011 - 2019 Ford Explorer Discussion 8
M 2014 seat wiring diagram or connector view Stock 2011 - 2019 Ford Explorer Discussion 6
M Disabling 2nd row seat belt airbags Stock 2011 - 2019 Ford Explorer Discussion 7
B Driver Seat Lift Kit Stock 2011 - 2019 Ford Explorer Discussion 6
P Rear seat belt receptacle replacement? Stock 2011 - 2019 Ford Explorer Discussion 0
C Best baby seat and base for 2016 Explorer Stock 2011 - 2019 Ford Explorer Discussion 7
L 2014 XLT 2nd row bucket seat wire harness Stock 2011 - 2019 Ford Explorer Discussion 1
T 2016 Platinum Drivers Seat AC / Heat doesn't work Stock 2011 - 2019 Ford Explorer Discussion 10
Similar threads
