J_C
- July 30, 2009
- Florence, KY
- 1998 XLT 4WD 4.0L SOHC
I have conflicting information about which pin #s on the pictured connector. On the wiring diagram I posted previously, it would have been pins #1 and 16 for the rear sensor, but on this diagram it is pins 21 and 22.
I would check both of these combinations, but ultimately if you want to know for certain you would look at the colors of the wires at the rear sensor, on the connector it plugs into, then either use insulation displacement meter probe tips to pierce that color wire at the ABS module connector, OR using an extension to the multimeter leads, test for resistance between each contact of the ABS sensor connector's two pins, and each contact in the ABS module connector.
Yes you should be able to use the OBD2 dongle and Forscan to see the ABS speed sensor data in realtime. I don't recall what the menu choices were but it should be obvious when you have the right one.
