Reverse only works on flat ground
wil bryan
williamearlbryan
williamearlbryan
Hi all,
I have a 2006 Explorer XLT V6 AWD... Picked it up recently from a rear brake job and within a day or two of the work shifting into reverse became a hard drop, and it stopped backing up any level of incline. I can still reverse on flat ground, and everything else operates well. When trying to reverse uphill the engine revs, but there is zero movement.
  • Is this a reverse band issue, a sensor issue, or a rebuild the whole transmission issue?
  • Is the timing just unfortunately coincidental to the other work or should I be concerned the mechanic did something (Ive had so/so experiences in the past).
thanks in advance for nay and all suggestions, really appreciate all you who help the noobs like me!
974X4BLACKSPORT
Location
FL
hudson
BLACK 1997 SPORT 4 BY 4
CHeck the fluid level?
JK080
Transmission Moderator
Staff member
Moderator
North Ga
05 F250 6.0
I cant see how a brake job would effect reverse, I think its just a coincidence.
Most of reverse problems with that transmission is due to the low band, only thing you can do is conform the fluid level is correct, if its full the transmission will most likly have to be rebuilt.
A Hi, my name is Anthony from Aruba. 2010 w/ no reverse Stock 2006 -2010 Explorers 10
T 2006 Ford Explorer XLT w/5R55S Automatic Transmission Slipping In Reverse Stock 2006 -2010 Explorers 8
G 5 speed reverse slipping Stock 2006 -2010 Explorers 2
R 2008 Explorer pop/clack sound when shifting into reverse (video) Stock 2006 -2010 Explorers 4
J XLT will drive in 2nd, no reverse or drive Stock 2006 -2010 Explorers 1
J Sporadic, Intermittent Whining Noise When shifting from Reverse to Driv Stock 2006 -2010 Explorers 0
Z No reverse Stock 2006 -2010 Explorers 3
G Reverse slipping Stock 2006 -2010 Explorers 2
A 2007 explorer jerks on slight throttle/idling/reverse Stock 2006 -2010 Explorers 2
E Electrical puzzle - no voltage at the kick panel but reverse lights work. Stock 2006 -2010 Explorers 0
K 06' Explorer won't reverse. Stock 2006 -2010 Explorers 6
W Reverse Gear Issues - What Does it Mean? Stock 2006 -2010 Explorers 0
N LED Reverse Lights Stock 2006 -2010 Explorers 2
X reverse sensors Stock 2006 -2010 Explorers 1
E 2007 EB V6, no reverse - 5R55 experts needed :) Stock 2006 -2010 Explorers 3
The-HewMan 5r55s started losing reverse then gone! Stock 2006 -2010 Explorers 0
B Explorer 2007 No Reverse! Stock 2006 -2010 Explorers 0
M 2006 (4th Gen) Explorer EB Reverse Wire Color Stock 2006 -2010 Explorers 3
E 2006 Eddie Bauer Explorer no reverse Stock 2006 -2010 Explorers 0
F Reverse Parking Sensor Stock 2006 -2010 Explorers 1
S Transmission Jump from Drive to Reverse? Stock 2006 -2010 Explorers 3
D Reverse is Reverse, Drive is Neutral, 1st is Drive Stock 2006 -2010 Explorers 2
R No Reverse Stock 2006 -2010 Explorers 0
K 2006 Ford Explorer Trans shutters in reverse Stock 2006 -2010 Explorers 1
A Explorer 2006 Considerable Jerk at Reverse Gear Stock 2006 -2010 Explorers 3
R Reverse Jolt, 2008 Explorer Stock 2006 -2010 Explorers 4
R reverse sensing system activation problem Stock 2006 -2010 Explorers 3
M My 2007 explorer goes into reverse hard when it warms up Stock 2006 -2010 Explorers 2
ahodges Reverse Sensor Issue Stock 2006 -2010 Explorers 9
L Reverse vibration Stock 2006 -2010 Explorers 2
A Truck shifts into reverse during hard brake Stock 2006 -2010 Explorers 2
M '06 EB 4X4 V8 Reverse Sensor + Slipping/Sagging Stock 2006 -2010 Explorers 2
C Delay in shifting into reverse Stock 2006 -2010 Explorers 3
R reverse sensors in 2010 explorer Stock 2006 -2010 Explorers 2
7 reverse/backup sensor location Stock 2006 -2010 Explorers 1
J Shifts Violently from Reverse to Drive Stock 2006 -2010 Explorers 0
V Loud Bang When Shifting Into Reverse Stock 2006 -2010 Explorers 5
S Rough Transmission and Reverse Jolt Stock 2006 -2010 Explorers 0
J Transmission jolt when shifting into reverse Stock 2006 -2010 Explorers 19
T Hard shift into reverse Stock 2006 -2010 Explorers 15
J Reverse Sensing System Stock 2006 -2010 Explorers 0
J Reverse Camera Stock 2006 -2010 Explorers 7
B Reverse sensing system questions Stock 2006 -2010 Explorers 7
A Skid plate solution...at least that works for me! Stock 2006 -2010 Explorers 1
W only fan speed 4 works Stock 2006 -2010 Explorers 3
C 2010 Explorer XLT AC Blower speeds 1-3 not working high works Stock 2006 -2010 Explorers 2
N Info-Setup-Reset no longer works Stock 2006 -2010 Explorers 4
Y Tire size that works with stock height and w/lift? Stock 2006 -2010 Explorers 6
B AC blows hot - compressor works - low pressure side VERY high Stock 2006 -2010 Explorers 3
E Sirius doesn't have sound but the rest works Stock 2006 -2010 Explorers 0
Similar threads
