reverse trouble | Ford Explorer Forums - Serious Explorations
reverse trouble
Derrick Kephart
washougal Washington
1991 f250 diesel
I just did a transmission swap on a 95 explorer and originally it made a grinding sound by the transfer case when in reverse and was not in gear. It would only go in reverse in 4low I taped on the motor on the transfer case and now it goes in reverse in 2wd and 4auto but when it is put in 4low I need to tap on the motor for it to work probably in 2wd. Any advice would be great thank you
