Your design of the flares look good completed and functional. You might have to widen you rocker skid bars to protect that extra width you added with tires and flares. I guess that all depends on how much mother earth and rock you want to get yourself into. There is no doubt that adding the access hatch for the fuel pump was a smart design. Anyone who has changed those flippin pumps out ,wished they could have gotten to it from the top.
May have to think along those lines. Thanks.
In fact I'm going to turn the rear flares into a small exo-cage protectant to protect that rear quarter panel. Front fenders I have several sets, but not the back.
Those off-camber rides on these WV mountain wet trails can be a little damaging when the rear wants to slide into an old Red Oak.
Obviously I need to fix the area that was cut out. This is looking straight down from the driver side.
The rear bed cage you can see in the top of the pic. I'll use that as a structural brace to enhance the strength of the outside flare.
First I found some tubing that has a radius that lays along both edges.
Then later it will be welded to the diagonal support of the cage.
Now it's apparent where this is going. Then both the outside and inside sheet metal will fasten to the tube.
So now I'll have an inside part of the cage that will protect the rear quarter panel.
But also it is directly in-line with the tubed flair. So now if one was so inclined could take a 20 pound sledge hammer and slam the rear flair with no damage to the quarter panel.
Not mentioning using the rear flair as a turning/pivot point against a rock or tree.
Not that I'm going to any time soon...at least not in the next week. But a month of hunting starting in 2 weeks, who knows.
Those open areas will all be tied into the new side cage giving it a true monocoque design which in itself is a benefit to a choped top truck.
So now you might even say that the flair itself is now a mini exo-cage.
Later I would really like to get one of those small tubing benders and make a flair that actually penetrates throught the side of the truck and attaches to the diagonal of the cage acting as both a flair and a small exo cage. Hmmm.
On another note, I'm tired of waiting for the 7 degree reamer from Snap-on.
They said it still on back order...next thing I said was forget it.
Going to find one today and be done with it.
Also some new 5 on 5.5 rims will be ordered.
