Thanks Hoss, it is starting to take shape.
He, terrible11, check out the vid of the fender.
James, I just think about all those years without a garage and how hard it was depending on weather. Now it's just a cake walk.
Got rid of all those dangling and unprotected wires under heater motor as in first pic.
Now to get rid of this birds nest. All these wires were on backside of that sheet metal inner piece I junked.
Also while I'm on a getting rid of ugly stuff...that piece of crap plastic or fiberglass grill that goes around headlights and connects to the top of the radiator support is just plain cheap and nasty looking. Although I did cut out the El Cheapo middle part and made a steel tubed center section the rest of it is crap.
I'm talking all STEEL but follow along the same lines it has now. Maybe frame around the headlights like it is now but with square tubing and mitered corners.
All ready have steel tubed fenders might as well have the same thing for a grill.
It's just a matter of time that a limb wrecks havoc on it.
Just got a brain storm of an idea while I was reading this overlong post. Why not continue the upper 1" x 1" tube that I made for the top horizontal peice out a few more inches and then proceed with going around headlights and continuing around to other side. Then have a good structural way to fasten that to the radiator support. Hmmm
Or use some smaller 5/8 sq. tubing. Hmmm again.
It would also have to be located across the front so that the existing foam that is there now will fasten to it so air does not go under my hood and make it want to fly off truck haha.
This little box of electrical connectors and dodads has been with this build since day one and is one of the most used tool boxes I have regarding this build.
Those yellow covered wires are my main power supply for all the front lights.
It also has two headlight relays wired with it. Now all the heavy amps go thru them instead of the headlight switch.
Now that's a whole lot better looking.
Terrible11, this is for you. Here are the quick disco's for fenders. This style is older then dirt and have proven them selfs in the racing world.
This is what the plunger pushes down to. Then it's just a simple quarter turn of the plunger that has a cam style cut in it that latches onto the spring and snaps in place.
Then just how long does it take to disconnect the side marker light and remove fender either for trail rides or more often then not, engine compartment maintenance...count the seconds.
Check the link below
http://smg.photobucket.com/albums/v81/honda2nr4life/Dana44 build/?action=view¤t=MOV04723.mp4
